Photo Gallery
Should I rebuild this properly? The bias ports and knobs are kind of ugly but this was a test chassis that worked so well I still use it. The output stage is a single ended depletion MOSFET (IXTH6N50D2?) source follower loaded with the light bulbs inspired by Nelson Pass. The B+ (for the MOSFET stage) is about 65V loaded, the MOSFETs have 25V and 2A across them. No gNFB. 6N8S (in this case) driving a 6P3S with a 5k load (or 6L6 but I didn't have one) driving the source follower. Speakers coupled by the KEMET caps on the front which work so well I show them proudly 🙂
The B+ for the tubes is about 280V and comes from a boost converter. !@V SMPS supplies the heaters, boost, "logic" etc.
For those who might care: The schematic for this light bulb amp. There is no hum cancel pot - it was for the version I would remake this with. R19, C10, C9 delete. 1R 40W for inrush. It's indestructable!
I changed the VA/PI/DR boards for the new version with optional LED bias for the input stage. This one has 12AV5GA (trioded) for output.
I also wiped off most of the dust 😛
That glow tube is STR75/60
Also shout out to Samsung... It's pretty dark in here, but this photo looks like it's daylight.
Did you have any trouble with oscillations? I’ve seen some folks try this tube and have to do some things to keep them in line.
Hello,
I wanted to submit a couple of images of my last "umpteenth" OTL ampifier based on E88CC and 6N6P tubes. As for me, the great thing is that I found an online company that creates nice metal / bronze labels cheaply. In this case I could customize the project itself by giving a name..
Dynaco ST70 upgrades.1. converted to 230vac power traffo, doubled the core stack, used graetz rectifier, 340 vac secondary, separate 40vac filament bias winding, replaced selenium rects with flatpacks.......
2. installed 5 way speaker binding posts
3. replaced RCA input jacks, installed volume controls
