Building process - The loudspeaker 1
Du you use the passive or active version? And what amp do you use?
I am using the passive Version. Level 1.
I have replaced the Jantzen resistors for the new mundorf ultra resistors
This crossover wouldn't pass any border control.
As for the amp, I'm using Line Magnetic with Russian tubes
I would recommend this amp to anyone, fantastic little thing. Similar to my First watt J2, yet with more body and thicker texture sound.
Waveguides I have can be quite resonant freestanding, they ring quite a lot tapping by finger, aluminium and plastic ones. But that all goes away when tightened to a baffle. You should damp them more with something if you wish, but not sure whats the most effective way, or if it makes any difference. That ACE -stuff seems nice to apply, but does it dampen?
Reactions: Mihai Cimpoeru
Even after tightening the horn to the baffle I could notice ringing by tapping it. I just bought those cohesive sport bandages, I guess one can apply quite a lot of force=damping. I'll try it out.
Reactions: tmuikku
I wonder how long they retain the elasticity and stickiness? Perhaps long enough. How about using just a rope? On my prototype freestanding devices I've just tied old t-shirt around it, tight knot so similar function, not as pretty though 🙂
Seen this?
Richard Feynman about how rubber bands work. He is my absolute favorite inspiration for imagining and reasoning stuff out 🙂
edit. while some basic rubberbands seem to deteriorate quite fast there seem to be also immortal rubberbands https://www.businessinsider.com/graphene-unbreakable-rubber-bands-2017-8?r=US&IR=T
So, I say just put bandage in and try out. Perhaps it lasts as long as the speaker in a way that when ever there is time for TLC also the bandage could be changed or swapped to something else. Its routine to fix old microphones for example, to replace rotten foam. Not best case scenario but not too bad either.
If there is risk a loose end can droop and rub a woofer cone below (I don't remember if the waveguide had its own compartment ) then secure the loose end somehow so that if it unsticks during the years it doesn't create additional problems.
Reactions: noamgeller
Those boards look really great!
Which ones are the Mundorf Ultra resistors, please?
What are you using the heatsinks on?
Are you using the tag strips on the underside of the board?
The big Red heat sink are for the smallish mundorf ultra resistors.
I bought them since Magico are using them in the a5 speakers and are writing:
" In addition, the crossover debuts Mundorf’s new M-Resist Ultra foil resistors for unmatched transparency, liquidity and power handling."
Since I still have a soft spot for magico, I had to try it for myself.
