What's wrong with the kiss, boy?
Now it's complete 😄
Reactions: twitchie and wg45
Hello Happy DIYers / Greedy Boyz!
I am thrilled to announce that Iron Pre essentials kits will be offered in the DIYAudio store. If you're a Smiths fan, you may ask, How Soon Is Now? They should be available for order before the end of the year. At this time, we have enough parts sourced for 100 SE and 50 balanced kits. Highlights include matched Toshiba JFETs from Nelson Pass and high-nickel CineMag transformers. The next obvious question is, how much? Costing is not final yet, but the goal is $100 for the SE kits and $125 for the balanced kits; a tremendous bargain. We have contingencies for all the parts, and we hope that this will be a permanent addition to the store. However, for now, we can only promise what we've got. Get 'em while you can.
Click the link below to see what will be included in the kit, answer a few questions about what you might like to see in the future, and get on the list.
Note - The n-channel JFETs will be 2SK370.
https://airtable.com/shrLnhLlLHG8KgxQk
I advise using Slagle's 200$ set, simply because I did tried those ( and other Slagle products which I also tried, including most expensive- most having slightly different arrangement of taps so least expensive ones being suitable if desired connection with gain)
No reason that any other quality AVC can't be used
yup, go for it, buy package from Store ( bargain) save Cinemags for some other purpose
  • Thank You
Reactions: tamra
