Yes, NTC on this boards, they are below the cables, you can see the legs only:nice
having soft start/NTC?
can't see them ...
Waiting for some BD from Mouser, they are on back order but should arrive next week or so.how's work with amp side?
Until then the M2X will be turned on tomorrow for the first time
I'm going strictly Kosher there - only FW M2 is proper M2
any other iteration is .... something else
I know, and maybe I will build the original one too, but there were no boards available, so it was a practical decisionI'm going strictly Kosher there - only FW M2 is proper M2
And for a Greenhorn who builds the second power amp (okay, third, umpty years ago there were some Quad 405s) it's more than fine
Don't forget the NTC's get hot. Keep the wires away.Yes, NTC on this boards, they are below the cables, you can see the legs only:
Thanks, they are 1 cm (0,4 in) away to the side and 3-4 cm (1,2-1,6in) to the top.
That's how the boards are constructed, I hope it's enough.
Maybe next week or so, at first without chassis as always.Anybody fire up a Scryer yet? I hope to very soon…
PS is ready. Working on soldering the Scryer PCB's now.Anybody fire up a Scryer yet? I hope to very soon…
I was curious about what was going on in the Serbian newspapers that ZenMod wraps
PCB's in.
Found out if you set Google Translate for Serbian-English the camera
will magically overlay an English translation.
Now I'm all caught up on the doings of Serbian Celebrities!
For those of us with the LM334 Daughterboard PCB's I went to these ZenMod posts for details on the daughterboard Section:
https://www.diyaudio.com/community/...ghty-babelfish-m25-schade.389982/post-7121057
https://www.diyaudio.com/community/...ghty-babelfish-m25-schade.389982/post-7121061
Yes, I also received the 334 daughter board. Went together nicely. I’ll finish stuffing my boards tonight, and then hope to have amp singing tmrw. 🤞
The singin’ Scryer! Came together without incident. Everything biased up easily and offset was no sweat. I can share more specifics later, but right now I want to listen to some music 🙂
- Scryer ... or how F8 met Mighty SissySIT
