Chassis Discussion
Hello Gianluca. I will soon be ordering a Mini-Dissipante 3U chassis (330mm X 300mm) for a Neurochrome Modulus-286 stereo amplifier. I would like to have some custom CNC work done on the back panel. This would involve holes for an AC power inlet (Bulgin PF0001/28) and 2 holes for XLR connectors (Neutrik NC3FD-L-B-1). If I send you a diagram showing the positions, could you make a CAD file?
Thanks in advance,
Dave
If anyone ever has to transport a 4U mini-Dissipante, I found Pelican makes a perfect sized case. It even comes with foam inserts to boot (some cutting required). Hopefully the transformer stays in place.
Reactions: 1 user
Joined 2011
Hello - Are DXF or DWG files available for the new monoblocks? I can't find them here or on the Modushop website. It doesn't look like the monoblocks are designed with IEC, Neutrik connectors or slotted binding post holes, so I want to add those plus a pilot light hole on the 10mm front panel for an LED.
Thanks -Glen
Joined 2011
Hi Glen,
Sure, I'll send them to you by PM on monday morning as soon as I am back to office. We have drilled some rear panels with the same cut-outs of the Deluxe chassis, I'll share that file with you as well so that should help you finish your project
Hi Gianluca - The Deluxe chassis cutouts are exactly what I am looking to do. Which "drilling panel" entry do I select on the order and at what quantity, 1 or 2?
Thank you!!
-Glen
Hello all,
Apologies if this has been covered before, but a quick search didn't bring up any results. If I ordered a chassis (Dissipante and/or Pesante) with a 3mm panel, can I order a replacement 10mm panel and do a direct swap? I believe I kept the spare hardware from the chassis, if that is necessary.
Thanks,
Kellis
Hello,
I am sure this has been asked before, but I am interested in front switch on the Deluxe 4U aluminum chassis. Something similar to that on the ACA chassis front panel, of course a switch properly selected for AC voltage and current. Is it possible to customize the front panel for this?
David
Hello,
David
Mouser sells some very nice anti-vandal switches with 1 or 2 LED lights in them. Here is the link for the one that I bought a few months ago; https://www.mouser.com/ProductDetai...B6uO5NlYgSg==&countryCode=US&currencyCode=USD
This is a great switch with red (standby) and green (on) LEDs. It fits perfectly in a 5/8" or 16mm hole.
I assume you are talking about this? If so, it's definitely possible to do it!
If you want a hole for a different switch feel free to send me the technical drawing for it
Thanks. That is great to know. I am still deciding on a switch, one of the push button Anti-Vandal switches from TE or ESwitch that can be installed on a 10mm panel should work perfectly and is AC rated at 16A (I think the switch on the ACA chassis is a LV DC rated switch). Still working how that would effect use of the back of the front panel for mounting boards to find the best location, but should be very close to placing an order and customization request. I will send a drawing of the switch I intend to use with the order, as well as the location (dead center may impact panel utilization).
David
Reactions: 1 user
