Best cabinet plans for Markaudio Pluvia7HD
Where are you? People have found interesting sources for good felt. Wool should be fairly widely available but sometimes pricey. Recycled cotton felt is becoming more commonlu avaiable. Some hempsubstitutes like manilla can also be found. Felt is used in pianos, under carpets (particularily older cars), and insulation (think gor heater blankets and such).
dve
https://www.airstep.com.au/product/premier-pad/
This is the 14mm version.
Info:
Airstep Australia manufactures, warehouses and distributes the Airstep range of carpet underlays and is seen as a market leader in the floorcovering industry in Australia.
HIGH PERFORMANCE RECYCLED TEXTILE FABRIC UNDERLAY WITH MINIMUM 30% WOOL AND 70% RECYCLED CLOTHING CONTENT.
A commercially rated underlay found in many high traffic areas around Australia. Great for pub and club type applications. Environmentally friendly product with base constituent ingredients essentially recycled textile fabric. A significant improvement on traditional hairfelt products of the past.
REDUCES NOISE TRANSMISSION
THERMAL RATED
ASTHMA AND ALLERGY FRIENDLY
UNDERFLOOR HEATING
Airstep underlays will not only extend the life of the carpet but can significantly reduce airborne and impact sound and help prevent the loss of heat keeping the workplace environment comfortable and energy efficient.
Airstep Australia's Architectural representatives are able to provide you with a detailed specification for your individual project.
GRADE: Heavy Commercial
I installed Pluvia7HD in various boxes and found the cost performance of DDVP-10-ML to be the best.
The sound quality is sufficient for my needs and I have no complaints.
The material cost is 25 USD (3,440 JPY).
12mm plywood is 18.2 USD, SP terminal is 4.4 USD, and sound absorbing material is 1.6 USD.
Would this kind of insulation also be good for speaker cabinets. It says its made from recycled textile its called painter's fleece.
Nice!
since yesterday i've been following various projects for an active monitor to match the pc and markaudio pluvia 7 hd has a decidedly interesting sound. i also see your projects and all, or almost all, opt for these tall boxes with the reflex made in a certain way brought to the ground. i also see that you position pluvia 7 on the front panel flush with the outside and no one positions it on the inside edge of the front panel. is there a reason why no one has ever positioned it internally?
like this:
Code:
The basket is designed for front [surface or flush] mounting with slightly raised cylinders around the screw-holes, which would make rear-mounting more of a challenge. The latter also tends to increase diffraction effects in smaller driver sizes; the Markaudio units are designed with very shallow cone profiles & direct-bonded caps so they tend to have a wider polar response to higher frequencies than those with deeper cones &c.
