All-DHT amplifiers: no indirectly heated signal tubes!
Hey Andy, it seems everyone uses a 10Y but never a 10.
What mystical property other than a Micanol base does the 10Y bring
to the party other than OK to use as a class C Oscillator to 10 MHz?
Or is it simply appearance & perhaps a modicum of bragging rights? 😀
I've also seen many 5R4WGB rectifiers used here on DIY. For audio a poor choice,
in my opinion, the forward drop is the largest of this class. But useful to 10,000 feet
should we take it to Gobi Desert. And go to 40,000 at lower voltages.
I gave most all of mine away.👍
10Y is more common. Unlike 10, which was consumer grade tube for AC-powered radios, 10Y is designated RF. Military stocked-up on them, that's why they are relatively plentiful.
Looking at them and see no difference. Both RCA. Actually, one has filament on whiskers, and the other on springs.
Same here - I had a stack of them which I sold. They only fetched low prices, nobody seems interested. The go-to choice is the 5U4 which is a much better tube, or a 5Z3 which as far as I can tell is the same tube with a 4 pin base and usually a lot cheaper.
I am particularly interested in interstage schematics as I bought a set of Monolith Magnetics SA9 OPTs and IT transformers from a fellow forum member here. Having recently bought more efficient speakers I am now pursuing a class A SIT amp on the one hand (almost finished) and would also like to try out a 2A3 or similar as another highly interesting option.
Which Monolith ITs?
You'll see the Lundahl LL1660 come up in quite a few schematics but I don't think it's much more than "OK". It would be good to hear of some better choices. With sensitive speakers I guess you're looking at around 1:3 step-up? Or are you thinking 1:1 with a SUT?
Making step-up interstage (with few ten mA primary current) isn't general.
It's no coincidence that most of common IT are 1:1 ratio.
Any, if you like 10Y sound, try once graphite anode 801.
I have several 10, 10Y, 801a, but graphite anode 801 is "other category" in tonality.
I tried the 1E7G as an input tube when I had my most recent build breadboarded. Ran it in triode with halves in parallel. The amp is an iSET (inverted SET) using 6N6G output tubes. Details here:
https://www.audiokarma.org/forums/index.php?threads/the-nuance-my-inverted-set-diy-project.990205/
It sounded good overall and the bass was very distinctive and detailed. In the end I used 26s but I plan on trying it again in my currently breadboarded project, which is a directly coupled design. I didn't try it in pentode, I figured it might have too much drive for the 6N6G, which doesn't need much. Next time I'll try both pentode and triode.
Very much looking forward to seeing your introduction to this project in this forum!
Going back to the 124B for a moment, the FR doesn't look bad at low frequencies despite the 150hz-15K data. It's the HF that's down. It's a beefy transformer rated 5W, 65H inductance. I'm wondering if it could even make a 1:3 interstage to a PP output given its CT on the secondary.
-4 dB at 20K is not bad. But this is with 10K source. With lower impedance source, HF response may be better.
This transformer may work as interstage, but it will need parafeed connection
Nothing fanciful about 5 W at 120 Hz. 10 W 60 Hz wall-wart transformers are smaller in size.
Also, no controversy in low frequency response, which was measured at much lower power than 5 W.
All it goes to show is that transformer specs should not be regarded as something absolute: they may change quite dramatically by the operating conditions (source impedance, signal level, termination). A reputable manufacturer like Hammond specifies under what conditions the characteristics were measured, so that a user can figure how the transformer will behave under his/her operating conditions.
Reactions: directdriver
