TPA3255 - all about DIY, Discussion, Design etc
A full bridge class D amplifier (3e runs the 3255 in BTL mode) does not suffer from bus pumping, at least not to extent to warrant a huge bank cap. Typically bus pumping is caused at low frequencies for half bridge designs, if this is really a concern I'd suggest measuring the supply with a sub-100Hz say a 60Hz tone audio signal. You got me puzzled so I'll measure as well the supply on my 3e amps 😎 be puzzled!
Please don’t be puzzled. I probably don’t need the capacitor but I have a lot of them and I paid about $1/ea so I use them in all my projects lol.
you just solder a capacitor from the power pin to ground pin on the opamp.
Reactions: audiomovil
Bad news from my new DIY class D 10 channels amp. After some testing days, the reset led of the TPA3255 from 3e audio lit up. When I connect the speakers also the fault led switch on. Is it dead?
Thermal warning, is the heatsink hot? If heatsink not hot, maybe the heatsink is not correctly coupled to the chip. If bad thermal coupling chip gets hot and faults into OTW, heatsink is cold leaving the false impression that all is dandy
I have tried with an amtrams 0.1 uf but the sound has deteriorated significantly
The last time I actually used a cap across the power pins of an opamp was probably 15+ years ago when modding a Marantz cd63. Very fast video opamps were a popular “upgrade” and many would oscillate without a cap across the power pins. Are you sure you soldered the cap to the correct pins? It shouldn’t deteriorate the sound at all.
Yes, checked many times pin 4 and 8, but no way.
