Tubelab SPP first timer build
R104/204 - 5.1K 1/4W metal film:
RNMF14FTC5K10 or
RNMF14FAD5K10 or MBA02040C5101FCT00
R102/202 - 220R 1/4W metal film:
MFR-25FBF52-220R
MFR-25FTE52-220R
RNMF14FTC220R
If 1/4 watt not available go to 1/2 watt.
R106/206 - 75K 3W metal oxide
Try metal film: RR03J75KTB
Diodes won't slow B+, The 5AR4 does that.
In my builds the board is suspended from the case top. I forget the spacers I used, 1/2", 3/4"? Lots of tube sticking through the top. Once you decide on the spacers the 150UF cap, mounted on the bottom side of the board, will determine the interior chassis height you will need.
Cheers, S.
All now placed in 'My List' Digikey. Cheers.
What is the purpose of those HER108 diodes?
Collected today from the Post Office.
A very proud owner
To determine the optimum value of C101, using 'Silver Mica' is an expensive affair.
I would start with different MLCCs (C0G/NP0) and then replace the correct value with a 'Silver Mica'.
As already mentioned several times, the amplifier will also work without this capacitor.
Attached is an example of a 1 kHz square wave signal.
In the picture above everything is OK. A missing or incorrect capacitor was used in the bottom one.
Cheers for that, though i dont have an audio generator, so it'll be ears tuned and go from there. George from Tubelabs said it might not even be needed.
As you say, Silver Mica's aren't cheap...
Can someone enlighten me about using a Vol. control at the inputs?
I assume it should be Linear.
I know that Stephe https://www.youtube.com/c/SkunkieDesignsElectronics mentioned in post #39 that she would be using a 100K pot.
Saying that for R100 she would use a 1M 1W metal film and R101 a 1K 1W metal film, that the "higher power resistors sound - slightly- better/less noisy".
Any recommendations for the type of Vol. Pot to use?
Just my opinion Calpe.
You can't build your amp optimally on the first try.
buy yourself a selection of cheap components but in several values and do some tests.
Instead of taking only 1 silver mica of say 330pF, you take a range of 100pF to 1uF ceramic (or other) to do your tests and when you have determined the right value, you buy the right mica.
ditto for your potentiometer, take a range of 20K 50k 100k 250k 500k and 1M as standard and try it, it will always serve you for something else.
Reactions: calpe
Volume control pots are usually logarithmic, matching human ear's response. Alps pots are decent, and not too pricey.
Reactions: calpe
I must admit and its probably obvious by now that i am not a DIY person.
When i spot something of interest i have a few thoughts and if the urge gets to me, i'm up on my feet.
Yes, i take time in ordering parts as i want to avoid numerous postage costs and when of course import duty too.
So it boils down to try and get my parts list order as accurate as possible, so i really do not want to be left with items i'll never use, but thanks.
I look at George's Tubelab's SPP write up (although hacked and some text appears to be doubled up and not correct), read it to see if he suggests any changes etc.
The same for Stephe's Skunkie Design Electronics, she is so natural and hands on lady, and certainly knows her electronics, puts me to shame.
Not forgetting the very useful write up here https://wallofsound.ca/misc/diy/diy-el84-amp-project-part-2-circuit-board-and-chassis-preparation/
However, there is light at the end of the tunnel, spares part list is now 95% ready, just need to sort out my nothing special case.
The Transformers and Choke should arrive within a couple of days
Valves (tubes) and valve sockets have arrived, need to collect from Post Office on Monday,
Reactions: huggygood
@calpe,
I’m sure you will do well with the Tubelabs SPP and will have reason to be proud of your build once it is up and running. You may not have DIY experience, but you seem to be intelligent, careful and deliberate in your approach I believe you will be successful and well pleased.
I am currently building an amp to explore using Russian 6P15P power tubes (in stead of the EL84s) in the Tubeslabs SPP PCB. I plan to install
”posts” (just a short solid copper wire sticking straight up with a hook at the top) in place of the feedback capacitor, so that I can try different caps easily. I am eyeing one of these for an attenuator:
https://www.ebay.com/itm/2748637127...Sa8BgLrRxy&var=&widget_ver=artemis&media=COPY
Reactions: huggygood and calpe
Calpe,
I've used the remote volume much like these before and they worked OK, The only problem is finding 9 to 12 volts in a SPP build. The filaments are only 6 volts. Unless you are really set on remote, just get a 50K or 100K Alps Blue Velvet pot (same as in the picture in your link but no motor, board or any of the other bits) https://www.ebay.com/itm/272249742734?hash=item3f6359658e:g:vXMAAOSwU1FXP-Fb.
Reactions: calpe
Calpe,
I needed 5VDC for the Khozmo attenuators w/remote and used a small SIMPS tucked into a corner of the preamp chassis. Works well but takes up a little space.
Reactions: calpe
