CRC Power Supply (Class A amplifier)
calculate VA of each secondary voltage separately. e.g. 18 v may be for power amp. but 12v may be for pre or other circuit with low current.
something like this for softstart (circuit was designed by UK member based on diya softstart).
Are the diode bypass caps necessary when using MUR860? I am thinking no
Does anyone have a part number for the heatsinks that would work with the TO-220 MUR860 rectifier diodes?
I also kind of wonder if I need heatsinks for this supply as it is only drawing 100mA (phono PSU).
This will be too big a crc psu for 100mA. you can design something smaller with regulators. i have a to-220 rectifiers + crc+lm317/337 psu pcb if you need it, quite small.
Hi all,
I have the CRCRC almost done, but I can't decide what size filter capacitors to buy.
6x 10 000 uF
6x 15000 uF
6x 18000 uF
6x 22000 uF
I will power one board with 2pcs JAT501 (100W/ 4ohm). I will use 400W toroidal transformer, common for both channels
Thx.
