UGS-muse preamp GB
I just noticed a strange thing, the bypass diodes(D5,D6,D7) that are across the ldos are rated at 10V. If you use 24V power supplies D6 and D7 are ok with 8v across them but not D5 which has 16.7V(24-4(voltage drop across R21)-3.3) on it.
So with the standard 24V supplies D5 needs to be replaced, I use 28V power supplies so I need to replace all of them.
The actual ones are rated at 3A. As you increase the forward current the leakage current increases too so what is a minimum value that can be used for the forward current to protect the ldos?
Reactions: Pars and starcat
All these years that I waited to build this I hoped that maybe if I wait enough the panels will draw themselves as I want them to be but unfortunately for me that didn’t happen. In the end it wasn’t so difficult as it seemed years ago.
I have started with the idea to have both encoders and no push buttons but after I started to use the preamp I decided that I will go with only one encoder and the push buttons.
@Alex_twn there is one thing that I noticed and I am not sure if it’s ok or not. If I change the input type on the fly from the front panel and after I restart the preamp, after the restart the input goes to the same state it is saved in the settings and not what was previously selected from the front input buttons. Is this behavior normal?
Thanks @Ine.
I have 2 buttons (50mm each, cnc machined bought from aliexpress years ago) that I wanted to use and for these the faceplate would look like below.
