I am enjoying some ear deafening oscillation in my Vfet lottery pt.1 amp, at maybe 16kHz, where I can barely hear it, but the rest of the family goes crazy. It starts after the amp has been on for about three hours. It started doing this after I connected a pair of JBL 2169H and a pair Renkus-Heinz SSD 3301 compression driver. The Renkus-Heinz driver has been connected many times before with no issue. The newest addition to the signal chain is a 15uf protection cap on the Renkus-Heinz driver, the only passive crossover component. And the JBL 2169H. Both pairs are highpassed from 210Hz electronically via minidsp.
I have used the amp for 9 months with no problem. Maybe some really high pitched sinus tones, but nothing like this.
both channels?
checked in full range mode (amp working full range, driving any test speaker)?
tried with different PSU (any sort, 24Vdc will suffice for test)?
I can turn it on again, wait 3 hours and see what happens when I disconnect one of the drivers.both channels?
If I turn off the amp and on again in a minute, the problem disappears.
I have another PSU I can try as well. Always double up. 🙂
The speakers current tweeterless configuration:
I did not notice if it was both channels, but I think so since the highpitched noise had excellent soundstage.so, next time observe is it both channels
if yes, it's some common thing - PSU
that's the easiest thing - using second PSU and if problem is gone, simple
if not, then realizing is it from amp itself or from before amp (source, DSP)
So far so good. But I can still feel a ringing with the new PSU. Must be very annoying for bats. What is the best alternative non-switching supply to replace these ringing bricks for the V-Fet lottery amps?
Is that not just another filter for the switching supply?There's a dual-mono linear voltage regulator board for the VFET amps called Tuba. Gerbers are on the Forum, order PCBs from your preferred fab in China, plenty of fun.
again, both channels?
I think so, but I changed the PSU, and I have not experienced the loud ringing in five hours now.again, both channels?
I am not putting the defective PSU back to verify.
The faint (to me) noise that is still there after switching PSU is similar to the coil whine I got from a Philips Hue Led strip when I connected two lengths of strips to the same Philips Hue SMPS. You can do that, according to the manual, but it resulted in an annoying coil whine that filled the room, and I had to buy an extra Philips Hue SMPS to make it go away.
It is difficult for me to place if it is coming from the speakers or the V-FET SMPS, because it just fills the room. Mostly annoying to my girlfriend, who thanked me tonight when shutting it off after an eight hour "stress test" with no more oscillation sounds with the new SMPS. But with a lot of coil whine that I can choose to ignore, but others with less worn ears cannot.
That is why I want to move away from a PSU with a coil, not meaning to be rude to Mark Johnson and his Tuba. The Tuba will most likely be too complicated for my skill level anyway. But if the Tuba uses two SMPS then they will endure half the load and have less to whine about, just like my Philips Hue light strip SMPS.
It only goes to 16KHz. Spectrum Analyzer app goes higher but does not really detect anything.I've used an app called Spectroid to track down noises. It's a basic spectrum analyzer.
Hi, if it is 16KHz, then I think it is not SMPS related. Most SMPS's oscillate at more than 30 KHz. Since 16KHz is within the audio range, I strongly suspect the amplifier. Most probably the inductive/capacitive loads of the speakers are causing oscillations. Some sort of correction has to be introduced in the negative feedback path within the amplifier, IMHOIt only goes to 16KHz. Spectrum Analyzer app goes higher but does not really detect anything.
I think I have narrowed it down. It is the damn Nutube Korg B1 Triode preamp that is ringing from the music that I am playing. It is a known issue with the preamp. It is ringing for a minute after closing the music, so not obvious at first. But the sound did improve when switching to new PSU for both the Sony V-Fet Lottery P-channel amp and the B1 Triode preamp. I will order some butyl and sorbathane to try and dampen it. The horns make it worse I think. I don’t know if it can ring from the speaker membrane acting like a microohone, or from vibrating the aluminium chassis. Most likely both. I love the sound so much that I have two finished B1 Triode preamps and another to build, but if I can’t dampen it somehow I will have to sell them.Hi, if it is 16KHz, then I think it is not SMPS related. Most SMPS's oscillate at more than 30 KHz. Since 16KHz is within the audio range, I strongly suspect the amplifier. Most probably the inductive/capacitive loads of the speakers are causing oscillations. Some sort of correction has to be introduced in the negative feedback path within the amplifier, IMHO
time to resort to ECC88
don't use force, use a bigger hammer ......
... I have two finished B1 Triode preamps and another to build, but if I can’t dampen it somehow I will have to sell them.
Have you considered Pete Millett solution over here?
I wa
I was clever enough to solder the nutubes pins to 4cm wires and then hang it in silicone. Didn’t help. Then it fell down. But butyl and sorbathane are on the way!Have you considered Pete Millett solution over here?
- DIY Sony VFET pt 1
