You mean that most micro-details are created when you do not use a box. Yes maybe.
That is very misleading. An OB just delays any reflections from the inside walls to the walls outside. In a box you are trying to contain, control, and remove the back wave. In an OB you just let it bounce around the room causing other issues.
OB is not a cure-all. One of the “boxiest” speakers i have every heard is an OB.
dave
Thanks, Very good answer.Good quality near-field studio monitor (speakers) are designed for exactly this purpose - to reveal small nuances in the music, so that recording / mixing engineers can hear fine details.
So what goes into the design of a good studio monitor? Once you know that, you have a good idea how to make good speakers yourself.
It's not about magic boxes/ stuffing/ speaker mounting. It's mostly about the flattest possible frequency response, along with reasonably well controlled treble dispersion. This seems to come down mostly to finding good drivers, designing a good crossover network, and to a small extent, controlling diffraction from the edges of the enclosure.
Pick drivers with very flat frequency responses within their intended frequency ranges, and you are probably 70% of the way there. Design a really good crossover network, including time delay compensation for the tweeter, and you are 90% of the way there. Get the box volume / port tuning if any right, you are 95% of the way there. The last few percent are from details like rounding box edges to help reduce diffraction problems from the edges of the front panel.
To get the details right, you have to be able to accurately measure frequency responses at every stage. Calculate, build, measure, tweak, repeat. The "measure" stage is where DIY has a huge disadvantage. The pros have tools like very expensive Brüel & Kjær measurement microphones with ruler-flat frequency responses ( https://www.bksv.com/en/transducers/acoustic/microphones/microphone-set ), and access to real anechoic chambers.
At the frequencies where it matters for revealing musical detail, this mostly down to the moving mass of the speaker (Mms)and force constant (BL product). These things are designed into the driver. You have no control over them, other than to buy the right driver in the first place.
Remember that the frequency response and transient response are tightly locked together - one of them completely predicts the other. A perfectly flat frequency response equals an infinitely fast transient response (ability to stop and start again). Neither ideal exists in reality - but the flatter the driver response, the better it's transient response will be, and vice versa.
And yet, there isn't a single good quality studio monitor using an open baffle.
Why is that? Well, open baffles produce disastrously bad bass response, and usually disastrously bad frequency response up through the midrange as well. See attached pic showing predicted frequency response for an ideal (flat response, zero-diameter) speaker mounted in a circular open baffle. The bass rolls off gently starting at quite a high frequency, so there is very little bass. Sound from behind the baffle interferes with sound from the front at multiple frequencies, producing peaks and dips in the frequency response.
(In real life the midrange and HF peaks and dips are less extreme than they are in the simplified mathematical model. But the problem is still quite real. Open baffles do not produce anything close to a flat frequency response.)
Why does OB retain a niche popularity in DIY? I can only guess. My guess is that there are four reasons.
The first one is the obvious one: open baffles are ridiculously simple to build. No carpentry skills necessary.
The second one is that by producing little bass and a slow bass rolloff, they can give the illusion of more clarity elsewhere in the frequency range (IMO this is rather like chopping off your legs to give yourself the illusion that you have lost weight.)
The third is that they avoid "boomy" or "boxy" sounds resulting from poor port tuning or poor damping of internal box acoustic resonances. (But well designed studio monitors don't sound boomy or boxy - it's a matter of a properly designed, stuffed, and tuned enclosure.)
The forth is that some people like the wash of reflected sound coming off the back of the open baffle system, so much that they overlook the tremendous other failings of OB speakers. Other people hate that same sound. In DIY, it is common for a builder to fixate on one single aspect of performance, to the point where they completely overlook massive failings elsewhere.
Detta är en hörselillusion. När du försiktigt filtrerar bort den djupa basen, med en långsam roll-off, låter musiken mer artikulerad. Detta blev mycket uppenbart redan i början av 1980-talet när Sony började sälja sina Walkman-kassettspelare med lätta över-örat-hörlurar. Dessa hörlurar producerade samma sorts svaga bas som gradvis föll under en ganska hög frekvens. Och den svagt sluttande lågfrekvensresponsen producerade samma subjektiva illusion av mer artikulerad och tydlig musik, om du kunde förbise den nästan fullständiga frånvaron av faktisk djup bas.
Du kan lätt höra den motsatta änden av samma illusion också i hemmabiosystem med för hög subwoofernivå. Massor av djup kraftfull bas, men det resulterande ljudet är lerigt och mindre klart.
-Gnobuddy
Thanks Dave.Det är väldigt missvisande. En OB fördröjer bara eventuella reflektioner från innerväggarna till väggarna utanför. I en låda försöker du innehålla, kontrollera och ta bort backvågen. I en OB låter du den bara studsa runt i rummet och orsaka andra problem.
OB är inte ett botemedel. En av de "boxigaste" högtalarna jag någonsin hört är en OB.
dave
How about a 'meta-material'?
KEF has used 3D printing and modern computer mathematic techniques to develop a meta-material to create a “maze” for the HFs. This work was, AFAIK, started by Hegeman with this loudspeaker (there is a thread [or more] on the subject). Then teh Hegeman 1, a Speaker BUilder article, and the Morrison loudspeaker, are marks in the evolution of the technique.
dave
Nice pictures. Never seen before.KEF has used 3D printing and modern computer mathematic techniques to develop a meta-material to create a “maze” for the HFs. This work was, AFAIK, started by Hegeman with this loudspeaker (there is a thread [or more] on the subject). Then teh Hegeman 1, a Speaker BUilder article, and the Morrison loudspeaker, are marks in the evolution of the technique.
dave
As important as FR, is what is the frequency response of the same driver 10 dB down, 20 dB down, 30 dB down, 40 dB down form a paying 0dB signal. If they do not mimic the 0dB response the driver will not have as good a DDR.
If your only tool is a hammer, everything gets treated like a nail. A FR measurement, as we see today, is like that hammer. It is only one of many tools. It gets leane don way more than it deserves because it is the tool we have.
dave
Thanks, very good answers.
English please.
dave
diyAudio moderation team
Would it be fair to say there are the same number of modes but that their spread changes?
King has shown that Bradbury’s work on slowing speed of sound was not in fact what happens.
We are talking about a distribution of modes. Just like a room, but inside the box, usually simplier, and smaller in “time”. Just like a room we are trying to distribute them such as to minimize their impact. A simple rectangular rbox will have 3 primary modes, as you add internal complexity things grow more complicated.
dave
For all the interesting references to open baffles, the extremely small values referred to here are unlikely in most instances to result in much that would normally be called dipole behaviour -especially if there's a gasket present. I'd probably give the slightly more prosaic answer that the most likely outcome will be that you simply bleed off pressure, as you've introduced an air-leak -it just happens to be around the driver. Once upon a time, this was a fairly common means of tweaking output if it was overloading the room. If you go far enough, you may (will) get some cancellations, but 1.5mm is unlikely in many instances to see much in that sense.Scottmoose
What have I done when I put a distance between drivern and the box?
One distance (1.5mm) on every screws.
It is a closed box.
Leif
Scottmoose
It is a closed box.
Are you isolating the driver from the box mass. This, in the end, can greatly reduce the DRR, as now all (almost) of the rection energy/movement is limted to the basket, the distance it moves will increase, reducing DDR, burying the micro-detail under that movement.
That is why you see the drivers tightly integrated across teh box mass to reduce this movement dramatically and improve DDR.
dave
Thanks to Dave, Gnobuddy, Scottmoose and all of you who contributed so much useful information.
The more you learn, the more complex it becomes. It is understood that manufacturers have a hard time getting a "perfect" driver. However, Alpair has come a long way when it comes to full range.
I have a faint memory of seeing at least one old speaker design where the woofer was mounted on a separate sub-panel, and that panel was mounted with spacers to stand it slightly forwards from the front face of the speaker enclosure. There was a narrow slot all around the edge of the sub-panel, between itself and the box behind it....the most likely outcome will be that you simply bleed off pressure, as you've introduced an air-leak -it just happens to be around the driver. Once upon a time, this was a fairly common means of tweaking output if it was overloading the room.
In that design, the idea was to use the resulting radial slot all around the speaker as the port in a ported system. Roughly speaking, the dimensions of the sub-panel set the length of the "port", and by adjusting the spacing between box front and sub-panel, you could vary the cross sectional area of the port, and so vary the port tuning.
It's an interesting idea, I think. Basically, a variant on the more commonly used wide and narrow slot-shaped port. Harder to calculate, though, as the cross sectional area of the "port" varies with radius as you go outwards from the speaker centre.
As a bonus of this approach, moving the woofer slightly forward in this way might help a little bit in time-aligning the woofer and tweeter around the crossover frequency. If you used nominally 1" lumber for the sub-panel (actual thickness 0.75"), and a 0.25" spacing from the front of the box, the woofer is mounted a full inch forward of the tweeter, giving you roughly 75uS of time delay compensation.
Our old rule of thumb was that a simple way to guess at a first-pass value of time delay compensation needed, was to start with the time sound waves take to travel the depth of the woofer cone (from dust-cap to front panel). Typically in the 100 uS ballpark.
-Gnobuddy
Put it this way: if you start out with drivers with ragged and uneven frequency responses, and a gap between usable woofer and tweeter frequency ranges, no amount of faffing about with meta-materials or golden ratios or anything else will help fix the resulting speaker.If your only tool is a hammer, everything gets treated like a nail. A FR measurement, as we see today, is like that hammer. It is only one of many tools. It gets leane don way more than it deserves because it is the tool we have.
You can't polish a turd, as a former co-worker accurately (but inelegantly) put it.
It takes a fair bit of good engineering to produce a driver with a very flat frequency response, and in practice, I've never measured a driver that was very good at flat FR, but very bad in some other key parameter. (Particularly if you also look at polar response, i.e. FR at a few key off-axis angles too.)
I don't mean to question your level of expertise with speaker design, simply to avoid leading Leif in such a way as to miss the forest for the trees. In other words, to start out by focusing on the most important parts, not the minutiae.
The starting point for a good speaker is drivers with good frequency responses, and good control of treble dispersion. Add in a well designed crossover network, put it in a well sized, stuffed, and tuned box, and you have now avoided many of the worst problems that tend to plague a lot of speakers. You already have something good, in other words.
Everything else - chamfered edges, golden ratios, etc, are more about small amounts of fine-tuning to something that is already good. They make a good thing better (but won't make a bad thing good).
IME, golden ratio speakers are not really a thing outside of DIY builds. They waste far too much wood. For production speakers that have to be made in large numbers and sold at competitive prices, what I saw was panel dimensions chosen to provide the right interior volume, but also to fit well into the usual 4'x8' sheet of MDF with minimal wastage, and to have a footprint that let them sit in the sort of space they were likely to end up. For nearfield monitors, that typically means ending up on rather small speaker stands, or worse, being plopped down on a desktop.
-Gnobuddy
Golden Ratio looks cool. They are fun. Audio Note are close to GR. Some of the Devores. But the very price concious boxes will have a material optimization step in the design.
This cut for a 13 litre CGR is pretty good.
And certainly smooth & flat is nice. And if there is an XO the drivers need to overlap sufficiently so as to make for a chance with the XO desogn (the hardest part) to work.
But you see people who love loudspeakers with ragged resonse (woofers in Thor), or less overlap than you would like if you have an XO (Zu), or not that flat FR (Ecplise).
The FR measurement is helpful, but the siituation is much more complex than that one parameter. And one of those parameters (a multi-input one) is the set of compromise that need to go into the speciific loudspeaker for the particular person.
Leif has been playing with drivers that are very good.
dave
dave
I wouldnt say that. To build a good baffle can be quite a challenge, because there's inherently less structure available for strength and rigidity.The first one is the obvious one: open baffles are ridiculously simple to build. No carpentry skills necessary.
Yes and most of the popular builds easily circumvent that with a "helper" woofer.The second one is that by producing little bass and a slow bass rolloff,
They certainly do that. I consider part of a "boxy" sound is all that noise inside the box coming back at you through the rather acoustically transparent cone area. I see that one hasnt been mentioned yet. With enough SPL inside it comes through the cabinet sidewalls as well; moreso in a thin walled, unbraced enclosure of course.The third is that they avoid "boomy" or "boxy" sounds
Yeah. Be it an illusion, along with the other junk gone / fixed It's something that makes me and my ears happy. Wash is a pretty ugly word; from what I hear back there it's not at all chaotic sound spraying every which way.The forth is that some people like the wash of reflected sound
There's available this program called the edge, which you can use to locate your driver in a better place on the baffle than that which produces the "Open Baffle FR" response, shown. Let it be known all OB designs dont necessarily make that worst-case response...
There are many drivers on the market. Some are amazingly good. Some less good. Sometimes it's fun to get pretty good sound from a little cheaper driver.
Of course, you can not conjure as much as you like.
I have tried both expensive and cheap drivers. Carefully selected from those that exist. Can name a few.
Scanspeak, Seas, Alpair, Visaton, Monacor and Fostex. All brands have given me joy and many good listening hours. I have a passion for building speakers and trying to get the last drops of good sound by building and optimizing. Just for fun.
I have received a lot of help from Scottmoose and Dave in my search for good sound.
It has been a blessing for me. They are unique in that they share.
If you think I take too much of your time, you can say no. I'm unemployed and have way too much time to deal with this. 🙂
You may be thinking of either the old R-J enclosure, the similar Eliptoflex or the slightly different though IMO related implementation by Supravox which they also call R-J. They are all basically 6th order bandpass.
I like golden ratio enclosures. They are not that wasteful of material IMO, nowhere near as much as slim and tall floorstanders. In the end, the acoustical design should trump material utilization though, outside of grossly wasteful methods like trans-lam, as pretty as it may look. Unless one plans a use for the cutouts. 😉
Have you built a box with the Golden Ratio?You may be thinking of either the old R-J enclosure, the similar Eliptoflex or the slightly different though IMO related implementation by Supravox which they also call R-J. They are all basically 6th order bandpass.
If you have done that, can you describe the sound they perform?
I have built large 142 liters enlcosures for a 15" and waveguide in the golden ratio and am currently working on near-enough to GR boxes of much smaller dimension for small drivers.
I would not say they have they "own sound". They may avoid coincident modes, assuming these are withing the driver's working bandwidth, but they don't add anything of their own on top of baseline performance, which they in fact should not. IOW, I don't think they sound different from any other form-factor of competent design. This is but one element of consideration in the whole system design.
- Full Range
- Golden Ratio speakers?!
