I wouldn't invest to much hope in this really Leif. If there where a substantial advantage we would see a lot of 1,61 oriented designs. We dont. This ratio is not like a hidden secret or anything... For instance, if you make all your bracing with the same distances, even when based on GR, you will get a number of surfaces that will resonate at the same frequency and Q value. So there might be a audio signature of this design - better, and even more irrational, would be to create bracing with no repeating distance i.e. totally chaotic - this will spread all resonances in the cabinet and make a more silent one than the 1,61 all-around based one.
I would say that diffraction is a far greater problem with a box - it seriously effect the frequency response. Look into that also (instead?) and see of you can make rounders of the edges of the box.
Good luck however you choose to proceed!
