Beast with 1000 JFETs redux?
Hi Patrick,
I can find this one where Nelson states that he is working with substitute parts. I believe I have either read or seen another video where Nelson says the same although concluding it is the J113 might be my interpretation given the amount Nelson seems to have bought of them. I can'r remember if Nelson has mentioned it or written it specifically here on diyaudio,
Mogens
Below is a higher resolution picture of the new Beast of a thousand JFETS. The new Beast uses the Fairchild J113 JFETS. As configured, the Beast can supply 20 watts into 8 ohms with balanced inputs.
Nelson has made smaller versions called the mini-beast and micro-beast. Nelson gave me a 48 JFET Mico-Beast which I use as a headphone amplifier. It provides about a watt into 32 ohms with a single-ended inputs. See below.
I am pretty sure this is not what Nelson has built.
In any case, if restricted to J113 only, this is how I would build,.
Fully balanced. 500 pairs per channel. 7mA 35V per JFET.
And very low distortion, if you believe in Spice.
e.g. 0.1% 64Wrms 1kHz into 8R.
0.001% 1Wrms into 8R.
Of course the devil is in the details.
For example DC bias drift. But can be solved.
Patrick
Here you go, schematics in pdf.
Of course lots more info in Spice file.
R11,12, V4 only needed once per board, but then 499R and not 20k.
R1~4 have to be one set per JFET pair.
JFETs have to be matched for Idss for equal current sharing.
Will get hot at 250mW each.
RL1 is of course the load (speaker).
Happy matching, 🙂
Patrick
Reactions: codyt
First step is to match 2000x J113 in TO92 package.
Plenty available at Mouser or Digikey.
Cost about 280€ for 2000x.
And that will keep you very busy for a long time.
Patrick
I'm considering to do this.
but I'm wondering:is j113 the only candidate?
Another thing I'm considering is: 64W is plenty of power for me, maybe I could scale down the thing to less jfets in parallel or it is better to have less bias current?
