ThanksDon Audio in Germany
two possible Cinemags - you have both titled in schm in post #1
eh, not living there, at least not in this life 🙂Ah! Sarf Lunnon's diffrent, innit? From living there or watching Only Fools and Horses?
speaking of ...... I did stumbled on little jewel lately - https://www.imdb.com/title/tt7988304/?ref_=ttfc_fc_tt
not directly comparable, but comparable amount of jolly stupidity ..... refreshing for sure
Hello Dan,Can someone point me towards the best place to buy the Cinemag Autoformers in the UK, or will I have to import?
Which one do I want to go for?
i think you found it already. But here is a link to Don Audio and its autoformers.
https://www.don-audio.com/audio-ausgangsuebertrager-transformer_s2
Cheers
Dirk
Another question.. Regards the LU board and the 2 large output devices, should they be seperated from the chassis/ heatsinks by a silver mica? Thanks again
if you have LU on small Aluminum pcbs - no need for mica , LU is already isolated form Al back of pcb ...... just put some thermal goop in between
IRFP- each needs proper isolator
small LU pcb - take care to solder wires to same, while small pcb is still not on heatsink
if you fix it to heatsink prior to soldering, you'll need blowtorch or two, and still no go
Very beautiful Cinemags have now arrived, assuming that I solder all the connections/ legs?
Thanks again
Thanks again
you got last iteration of pcb, where cutting outer 4 pins isn't needed
so, solder all pins - I mean - outer 4 are still NC, but if nitpicking, better mechanical arrangement
if you're nitpicking to other direction, no need to solder outer 4 pins
LuDEF commissioned by my Buddy ZeroWAF, Mod at Baby DiyA
he said - better that you make it ......
Photo-shoot
Photo-shoot
way for me, but no way for you ....... at least not from here
exactly the same for me - wanting some nice Drek from overseas........ then seeing how much for shipping .....
Late to the party, but very clean build, congrats 🙂
Following this thread, any news on LuDEF P?
- LuDEF
