LuFo Amp - 39w SE Class A from 28v Rail
There are 2 R121 on the board,is it where the unpopulated R121 the 0 ohms "resistor" should be?
Sorry, that’s a silk screen error on Gen 1 boards. It should be R122 (0R) and use a wire jumper if you are using the aluminum IMS TO247 adapter which has a 100R gate stopper resistor on board already.
No, you don’t want low ESR for the first cap in a CRC as it causes too high of a current surge in the charge cycle which leads to high ripple current. Low ESR is good for last rail cap right next to an amp output to give reserves in a a class AB amp. I should say “average” ESR rather than low.
Hmmm.
I was thinking that a high (average) ESR would generate more power/heat in the capacitor than a low ESR as the power is
voltage squared divided by R (ESR)...
But yes, on the other hand, the power is also current squared times R...But if the R is lower?
What about a small R ahead of the first C with low ESR?
That way the power generated by the high current surge in the charge cycle will heat up the R instead of the C?
What’s the consensus on appropriate chokes in 2022?
I know there has been success with MOT MD-803s btw xrk and Vunce.
Xrk, you also tested a MD-103.
dbel and jwjarch tested a MD-903.
Hammond has 195T5 and 195S4 as assumed good options.
Found this on Mouser: https://www.mouser.com/ProductDetail/Bel-Signal-Transformer/CH-4?qs=0/2GmT7MRM9RsVUzZKxOJw==
Would that work, or is it the wrong kind of inductor?
I think the 195T5 would be the absolute highest cost I would go for.
