Kirishima Fostex FE208e∑ build
Thank you, but I need a negative one, reverse as the baffle is in place.
Hmm, Google failed me again! 🙁 This is starting to become a problem as it used to be quite accurate or at least admitted defeat.
Oh well, like Dave suggested, a rasp is what I've always used for flaring out the backside of a driver's/whatever cutout plus it's randomness/ roughness is actually technically superior to a router's chamfer.
Ahh I know what might work, I have rasps as a drill bit, if that makes sense...might just work.
Found a great solution to chamfering post build ...simply angled my jig saw 45 degrees....
Reactions: aroS3 and LeifB60
