Push-pull 807 amplifier without global NFB
Let me share my current project, a push-pull amplifier with 807 output tubes. Since this is a rebuilt of my old construction, I wanted to reuse some parts, especially the chassis, power transformer and output transformer, at least the iron. I set some design rules for myself:
B+ should stay below 400V​
There will be no global negative feedback​
Local feedback in each stage​
The output tubes will be driven from cathode followers​
Perfectly symmetrical driving of the output tubes​
Possibility to connect in ultralinear, triode or pentode operation​
AB1 class of operation​
Around 10W or more output power​
Below 1% THD at full output if possible​
I know the 807 shines at 600...800V anode voltage, but I wanted to build as simple as possible. Also I don't feel comfortable with that voltage level.
The simulation is promising, see attached circuit diagram. I will add some measuring data later.
Edit: after simulation and measuring the actual circuit it turned out that global negative feedback is unavoidable. It is because the amplifier in open loop has too high output impedance (and relatively high THD). On the other hand, with GNFB one has to take care of phase margin, so that the amplifier should be stable under complex load. I tuned it by watching the step response and experimenting with various compensation.
I saved the current regulator diodes 1N5312 (3.9mA) and 1N5313 (4.3mA) current regulator diodes:
Microsemi - Current Regulator Diodes
They are connected parallel for 8.2mA idle current for the LTP. Also I wanted to reuse the Mills MRA-12 wirewound resistors (33k and 68k) that served well.
The bias is set with Bourns 3590S-2-103L multiturn wirewound potentiometers, also from the old chassis.
The first stage is a cascode, using E88CC tubes, my favourites due to excellent linearity. But in the new design I avoid exceeding the anode voltage limit. The driver stage were not absolutely necessary, but I wanted to drive the g1 of the output tubes from low impedance. So the effect of the Miller capacitance is reduced.
I wanted as few coupling capacitors as possible. The cascode and the cathode follower are direct coupled. There is only one coupling capacitor at the g1 of the output tube. Here I used WIMA MKS-4 (I think this is a weak point, it will be checked later).
There are reverse biased protection diodes between g1 and k of the cathode followers, not shown on the schematic. They prevent burn-out of the tubes when g1 becomes more positive than k (at turn-on and if the previous stage fails). This is mandatory for direct-coupled stages.
You might have some gain to spare, maybe look at feedback from the output tube anodes to the upper cascode grids. Needs to be cross coupled (U1 to U3 grid and U6 to U2 grid). Jhstewart9 has posted some schematics with this arrangement. You'll have to think how to get the required DC and AC levels, can be done with partially bypassed resistive divider.
For those who want to play with the LTSpice circuit. Any ideas how could I reduce the 3rd harmonic distortion component?
I used the 6L6GC model for the 807 tubes. At least the idle current predicted by the model at -30V g1 bias is 72mA, and I measured the same on the actual circuit. The 807 and the 1625 models were not so accurate.
Any ideas on improvement welcome.
