Danley Signature Series
Quad 12"
Ile3 seems interesting.
Kipman is there info about the directivity behavior?
Edit: well i think Fluid was in lookahead mode to my question posting the paraline video: something in the 120*×10*. Scarying from you Fluid ( even more since i'm in a 'Dune' mood and seen both Lynch and Villeneuve's part one in the last two days... i hope you don't use 'spice' or mess with giant worms... 🙂 don't want you to read my mind!).
This is something ( directivity) which i have not seen documented or discussed for the studio range too.
Well i must say i was doubtful about some actors choice but i've seen myself whining to have to wait one more year for part2.
Lynch's one got old. Still interesting but it would have need 2 more hours... i was astounded to see the steampunk aesthetics, i didn't remembered it.
When I trekked out to Danley Sound Labs last year, I recorded this video:
Danley Sound Labs SBH10 - YouTube
If you look at the pics that Erin posted, there's a subwoofer "hiding" on the side of that box:
index.php
index.php
So I'm going to speculate that it's similar to the Skinny Big Horn series, but with a waveguide that's barely there. Pure speculation on my part.
hey partrick good day ,is the shb10 coax driver having this kind of horn shape or a tube,? just like this on the photo
Reactions: dheming
The SBH10, SBH20 and ILE# use 5" coax with 1" HF diaphragms on multiple Paraline devices in an arrangement something like this:
I'd guess the connection of the HF driver output to the Paraline entry point, "116" in the above diagram, is probably around 25mm (1") in diameter, surrounded by woofer entrance points, "144" in the above diagram.
The connection to the Paraline would not be an actual horn like the coaxial driver you attached in post #299 uses.
Art
