Moving the mic up and down determines acoustics center where the drivers are closest in phase with each other. If Wolf used LR4 or something similar the drivers phase should be track each other to sum close to flat on axis at crossover point. If one of drivers is reversed it would create a deep null. However, I use it so I adjust delay in the x-o simulations.
When you take measurements of individual drivers (frd and zma) and put them into something like XSim which has minimum phase extraction capability and ability to change the delay you can simulate the crossover, so it will be mirror of what you measure with current x-o. You can modify the x-o by reducing the dips created by bigger baffle or sharp edges. Since I don't have the driver files I can't model anything but, say you want to add a bit of a boost in 3k, you might lower value 0.82 Ohm resistor in series with coil in tweeters filter, or change the capacitors values. However it will change also the phase. Basically you play with the components until you're happy with the sound or measurements, hopefully both of them.
Maybe, yes. There isn't necessarily a problem with a peak a little off-axis vertical. Sometimes it is preferred.If it is diffraction and you fill in the dip on axis, you will have a peak off axis potentially making it much worse.
That's why I wrote potentially. In my room it would be problematic. But if there is a measured flat response at 30 degrees off axis in room, why bother with it? In my opinion it's not detectable. But hey, everyone have their own spices to enjoy
I came across this thread researching their drivers.The SQ is really easy on the ears and non-fatiguing. Enough detail to not sound dull, and bass extension and tonal ability is quite exceptional.
If you would like me to compare to other kits, please ask which ones.
The woofers are REALLY worth the price, and likely should cost twice what they do. Basically you get a motor/frame similar to that of Wavecor, and a proprietary cone formula only from Rival.
The Wavecor tweeter goes lower for a 22mm than it has a right to with a low Fs, and a reasonably smooth response. It has low HD as used in this design.
If you made the cabinets no more than 1.5" narrower, this should not affect BSC that much, and the cabinet can be made deeper this way with the same volume specification. If that is your choice, one port can be used as the depth will be more accommodating, BUT- It will need to be of larger diameter than the ports I used. I used 2 due to the angling needed in the shallow cabinet, and the port mach air velocity speed reduction. It would be a minimum of 2" diameter (2.25"+ recommended) to combine the 2 ports into one, and that with an elbow would not fit in my cabinets. Remember that the larger diameter port will also be longer than they are in the box as I designed it.
Let me know if you have any more questions,
Wolf
It seems they are out of business maybe unfortunately.
they say they can sell items at this time dut=ring checkout and don't reply to email inquiries.
Its sad because I was very intrigued.
Not sure what is going on with RAD, but since the new owner took the reigns, prices have risen and access or admission has been drastically hampered. Not sure they arent completely inaccessible/unavailable but limited for sure.
Yes, they were great drivers, and Rival still builds them, but not certain a distributor is present.
New ownership, too bad. I tried to purchase some SB tweeters and Rival woofers but nobody responded. Before I purchased the big kit capacitors and resistors kit from Rhythm and Design - good value. Oh well. Maybe there's a way to purchase Rival drivers directly.
In my basket I still have 4 Rival drivers and 2 SB29 ring domesNew ownership, too bad. I tried to purchase some SB tweeters and Rival woofers but nobody responded. Before I purchased the big kit capacitors and resistors kit from Rhythm and Design - good value. Oh well. Maybe there's a way to purchase Rival drivers directly.
Thanks for the reply!Not sure what is going on with RAD, but since the new owner took the reigns, prices have risen and access or admission has been drastically hampered. Not sure they arent completely inaccessible/unavailable but limited for sure.
Maybe a Canada only thing right now as far as sales...
At least I think they are in Canada?
I'm from Ottawa, RAD sent my package from Vancouver area over a year ago. I have no idea what's going at RAD these days. They ship to everyone in North America.Thanks for the reply!
- Completed project: "Fenrir"
