Cheap soldering station suggestions for a UK student!
Hello!
So, I’m in the East Midlands studying a Comp SCI course which involves some soldering (pi based projects) and of course, diyaudio. Can you guys recommend any cheap soldering station like in Aliexpress?
Do I have to go with weller or hyko for some basics stuff?
Budget £50 btw
Thank you so much!
Sorry for not following up! I was working graveyard shifts in a warehouse and had no time 🙁
BUT, I made some money and can afford better stuff now! Also, I have an amazon discount programme as a perk from the work.
Now that I think more about soldering, I think I'm gonna do lots as I'm gonna set up a DIY CCTV camera system for my house which involves a lot of soldering. So, a reliable but adjustable temperature soldering iron would be great.
So, I'm going for well-known brands.
So, what about this Weller, the WE 1010?
https://www.amazon.co.uk/Weller-Professional-1010-T0053298399-Temperature/dp/B07CHZ132F
and this Hakko, HAKKO FX-888D?
https://www.amazon.co.uk/HAKKO-FX-888D-Soldering-Station-70W/dp/B077B9Q6SJ
Maybe I don't even need a soldering station if this variable tempearature soldering iron from Antex work as it is supposed to!
https://www.antex.co.uk/products/precision-range-soldering-irons/tcs50w/
See if you can dig up a Weller TCP soldering iron. They used to be ubiquitous across engineering, manufacturing, and repair labs across Europe. They tend to run forever and can be repaired if they don't. My first temperature controlled soldering iron was a Weller TCP. I bought the hand piece and holder and powered the iron with a 24 V transformer that I created from a 30 V transformer by removing a couple of windings. I think I was in 8th grade (late 1980s) and didn't quite have the cash for a full soldering station. I still have that iron and it still works, though I now use a METCAL MX-500 that I picked up during the 2008/09 recession.
Tom
