I really am not the right person to ask, because:
1: I haven’t heard Mightys (Zen Mod) beast myself
2: I have never tried the BA-3 purely as a preamp.
But there are some major differences that might affect choice between them.
BA-3: Feedbackless push pull gain stage able to swing everything, a real preamp with an exotic feedbackless circuit. Hard to find something like it, really. Has it quirks, but once dialed in can give the listener/builder exactly what they themselves choose, be it sugar or not, wide or deep soundstage, or focused, or something in between. Intensely natural sounding. And with proper bias, never ever a contributor to harshness no matter what distortion setting.
Waynes linestage: Wayne is wayne. Push/pull, high bandwidth, low distortion without becoming clinical OTOH a bit sweet sounding. Linestage with mid level gain, compatible with a wide range of amps. Miniature JFET soldering quality is very, very important for a stable circuit.
Pumpkin: check it out: Iron Pumpkin ; line preamplifier , SE and Balanced iterations – Zen Mod Blog
Inductive attenuation, super-symmetrical (SUSY), adjustable gain. No sugar according to Mighty maker, but plenty ways to add that. This is the preamp I am going to build in the end, not knowing when of course.
In addition to that, B1 Korg nutube is on my list as a must try. Along with so many other things
Conclusion? Impossible
Depends mostly on your preferences, and also upstream components, power amp and speakers (ie what sound signature do you like, how might the chosen preamp contribute to that, how much voltage swing (ie gain) is ideal for your combo of power amp and speakers, how complex or easy do you want the build to be, and how cheap/expensive? You want a stable easy to adjust circuit, or something with a lot of flexibility and hence a bit of a challenge too?
Only you can decide in the end. Some say try em all. That is not realistic in my case, so I have to read up, ask and try a few selected builds as things are now
The conclusion is simple. Build both. Wayne's will be easier, but have less gain, in standard
form. Also consider the Iron Pre, transformer gain, 6dB or 12dB. Power supply and relay switching all on the same board. See the "Keep it simple" thread. Very nice, some of us have built beta versions, not in store yet, but will be eventually.
Russellc
Russellc
Thanks ozorfis,
I have only two DMMs on hand at present. Need to borrow another to adjust the bias.
I adjusted the bias as per the guide and now the channel is on.
What rating transformer is ideal for power supply?
hydrovac - re: the transformer. What version do you intend to build? The answer is in Nelson's article re: rail voltages and suggested VA rating for the two main iterations. Depending on the version +- 24VDC rails (from ~18VAC) and a 300VA transformer may not be what you want. Read the article, then post any further questions.
Incredible page to bookmark. There are three parts. The Part 3 article is likely the most relevant to you, but reading all of them may be worthwhile. Also, Jim (6L6) includes a link in the very first post of this thread. I'd also suggest reading at least the first few pages of this thread if you haven't already.
FIRST WATT
FIRST WATT
I would like to add a manual muting circuit to my amp. I was thinking of having a switch that would control relays that would disconnect the outputs (maybe disconnect the inputs, too, so the amp wasn't "amping" while muted?). Would such a scheme work, or would it lead to pops when breaking/making the connection?
just mute input, simple switch (or relay) will do
you're not removing wheels when you park your car and switch engine Off
That would still allow any noise from the amp it's self out... Although I suppose muting the input would cover most all of the cases I can think of...
Is muting the inputs technically easier than muting the outputs?
muting inputs demands much smaller switch than muting outputs
So for either input or output, the muting action would be as simple as opening or closing appropriate line, no need for any fancy circuitry?
Just a switch on the input. Break the RCA hot (center). Switch up it goes to the input of the driver PCB. Switch down it goes to ground.
Gotcha, can do. Thanks!
Do not do this with the outputs.
I assume that's because shorting the output to ground would do Bad Things^TM to the amp circuits?
- BA-3 Amplifier illustrated build guide
