A tale of 12" subwoofers, distortion and 15 dollars.
ID=48.20
Ang=2.0 x Pi
Eg=66.00
Rg=0.00
Fta=0.00
S1=1000.00
S2=1000.00
Par=35.00
F12=0.00
S2S=1000.00
S3=1000.00
Par=165.00
F23=0.00
S3S=1800.00
S4=1800.00
Par=105.00
F34=0.00
S4S=3600.00
S5=3600.00
Par=35.00
F45=0.00
Sd=507.00
Bl=27.96
Cms=6.10E-05
Rms=13.17
Mmd=274.01
Le=4.28
Re=3.92
PH1=4P
S6=1800.00
Cyl=35.00
S8=1800.00
Cyl=35.00
S9=1800.00
Cyl=35.00
Pmax=1000
Xmax=15.0
Path=0.0
Mass=0.00
Re'=0.00
Leb=0.00
Le=0.00
Ke=0.00
Rss=0.00
Rms=0.00
Ams=0.00
Fr1=0.00
Fr2=0.00
Fr3=0.00
Fr4=0.00
Tal1=100
Tal2=100
Tal3=100
Tal4=100
Comment=NEW RECORD - NEW RECORD - NEW RECORD - NEW RECORD - skarddx12 - NEW RECOR
FILTER
0 0.01 0.0 -1 0 0.01 0.0 -1 0 0.01 0.0 -1
100 25 0 0
4 30.50.5
10.50.50.5
SSSS
1111
1011
0022
0111
111
000
Everything in every detail and even shifted slightly for the very reason that it all should be he’s right there and it’s also in that same anymore so if you look after 860 Hertz and beyond is a sequence of numbers are made up of 192 and 96 and 48 and so on. Those numbers and the speed of light are in the sim as well Is the dimensions of the kings chamber in the pyramid of Giza it does not look like that well go open a book a trigonometry on a circle or the divisions of 11÷7 is 90 and Wood it never becomes another degrees upon the circle and it all is the same thing at which .30° is also the parallax angle of the speed of light just barely off a little tiny bit. Just like the real speed of light is just slightly off of 30 as 29.9792458 divided up into four parts and you get 75 or .75 or 7.5.(And the distance to earth and the distance to Mars and this is the earth back again or something else whatever that is it just happened in 500 seconds to earth , 1000 seconds total to 250 and 750 in between and there’s a 750 , Or 3/4 or three× a quarter wave this gets even creepier if you look at the numbers on the template to draw circles or… 11, 22,33,44 ,88,132,176… Those start at 11 which is the radius of the sun 433 and 22 is Diameter as 866. And so on 1440° a phase is 176÷7 is an error there for whatever reason 175÷7 is 25 that’s obviously quarter weigh in another higher dimension and also 176÷7 leaves us with 1÷7 extra just like pi does. There’s much more to that story and way more to type if one could but …
This is spherical trigonometry at this point the decimal point doesn’t matter it’s what you’re referring to were looking at in reference from that dues.
It is a pain the ***, but what is in what that simulation is full of numerically and extrapolate all the numbers it’s ridiculous it’s absurd it’s some kind of a joke? No it’s absolutely positively every single thing in the universe verbatim and more. Not a cliché it actually maths out to those things exactly and it’s like offset of all of them which is being to find right there just like it is in 380 50238 days in 360° around the sun the same thing the same thing happens in all of these quarterly pipes if you apply it right that is what is going on not only the math medical reference to it but exactly verbatim and everywhere you check out the Saturn that has moved to 1462 , What is 4×365.238 instead of 360. And as you move away from the sun everything grows in the same way as it does in this same and then physics and in reality and all that information as it is in this Same and you can’t really mess around with it much before you immediately drop the 860 at -990 DB. Long story short if anybody wants to invest the time and looking at the numbers in the same they would never ever be disappointed. Not from the aspect of it being a subwoofer but from what the numbers represent and everything else and why.
The hardest people to show this / to explain it to you -are speaker people (they’re too busy looking at the ad information from a speaker perspective ) everywhere else (where they don’t understand speakers at all ) come ungl ued and are flabbergasted by the numbers if they’re at all into physics astronomy or I don’t even know where that would end or begin) because they understand the numbers. It’s really weird how that’s a gigantic ironic conundrum but it also defines so many things about how our perception of everything else including inside the speaker or out.
Can you put any driver in there should see it with a B in C 18 DS115 flat as a pancake buttery smooth yes the CSA is changed a little bit but there’s a there’s a math right there there’s a slightly expandable mask in that as well as the Devils That was in the details I’m back cross eyed looking at this little screen trying to type it up making typos already😀i’m about cross eyed looking at this little screen trying to type it up with out many typos already .
Still no higher math skills, but of what I followed can be condensed into the knowledge that sound expands exponentially [1/f] = octave [2:1] spreads and yes, drivers, speakers can be/are designed based it [me included]:
Fh = Fl*2^n
Fl = Fh/2^n
n = ln[Fh/Fl]/ln[2]
where:
Fh = upper frequency
Fl = lower frequency, or the XO point in most cases
n = octave spread
ln[2] = 0.6931
The driver position in a 300 cm pipe exactly give it a couple decimal points either I mean really give it the beans in fact let’s say the papers 299.792458 cm long and where would we put the driver as precisely as possible to which the void would be completely gone in every detail? No trace? Dead nuts on the money for that pipe.
104.76 cm?
If that’s what you get then that’s what the speed of light says as well. From there on out we can look at what that now is in the other pipes
This is the 6.2857142857 versijn (x4 ) of 1440°. You wouldn’t think anything of it except that it needs to be 25 not 25.142857142…. Not because I’m using 22÷7 per pie that is another self-explanatory issue another page in this in this book it’s noted by the Japanese long long long ago and I recently noticed an ellipse shape it was 1.75 inches in diameter that is also 44.45 mm across to the diagonal and at that pitch of that…That… Is what is represented by the hexagon has a cube on isometric craft paper it’s also the four on three that’s an equation for a sphere volume .
Which one radius equals one makes the equation for volume 4.18888888888 which is 240° on a circle based on radians. That’s also the number of speakers that are in contact with each other in the eighth dimension of the snorkel mask whatever that means I don’t even care I had to look it up on this total nerd math site we’re also the pics that same number 5238 is the maximum ratio of volumetric gainPer dimensional math of circles and radius diameter high volume and so forthIt levels off and it doesn’t matter if that makes any sense or not that is very specific to that number as are 1 million things that are about spears and rectangles and the speed of light yet I’ll enough someone decide to leave those information in a pyramid and here we are putting it into a speaker and in case you haven’t noticed yet there’s a lot of numbers out of the band with that need to be looked at and that’s where the information is that pertains to all of this you regardless . That’s where face angles and hertz Centimeters are suddenly know he’s in kilometers or maximum orbital radius or very specific directions of the sun or seconds or minutes years or procession of the equinox and 25,920 years or the bigger cycle on that which is the tilt of the access and it wobble at 432000 years which itself has a cycle of o192, 96, 48 and 32?? In between the 860 Cycle which has -990 DB and each of those forever to the end of our response there is another cycle which involves those numbers it’s offset him how it shares those every other 860. Every single one of these numbers thenIs then mathematically relevant and cross references a phase angle and the frequency analog 10 scale that in whatever way you look at it once you pick something out as a function of a planet allocation of a plant to be honest I can’t find anything that is a fallacy in any of it. Regardless if that’s a speaker and subwoofer or whatever take those numbers then and move forward with them when you arrive at visible light you’ll see the red shift it’s pointing out how that works it’s also pointing out this slowing down while the expanding universe is occurring of that procession of the equinox the 14620 frequency in your Sim should be 1440 if not that would just be simple math and not pertain to our own solar system in our planet . Because that would’ve been 144 Hz and it’s not it’s 143 down there all these numbers repeat over and over again and don’t ever stop if you wrote the number seven down on a piece of paper multiplied by itself over and over again is that many times has record of a function you would come out a number that resemble the big bang and that would repeat itself as well over an organ if you just kept on writing that number times 7×7×7 and you can do this in the other direction and come to what is essentially a helium and a proton to the center of the sun all of which can also be seen in the sim. Put the frequency response into high gear or low gear 0 to 2000 Road in scrutinize those numbers everything you see is not going to deviate from some very important other things which iOther details to extrapolate and find hard vac parts of the source system the sun or time on earth all stuck in the same exact numbers amount of seconds on her Steve out of minutes on earth in a day or a half a day are the same exact thing as the dimensions of the sun those numbers then go out to Jupiter and out to Saturn in the same exact way however acorns any proportion with leap year which then to find so many other things they agree 1462 is for leap years it’s also the minutes in a day on earth And 22 extra. All this spells out something maybe it’s just a coincidence or i’ll 20,000 of them plus the decimal points in the super deluxe mode. Where are the bone response and the cycles of peaks and valleys in between the super very much defined was a -990 TV is this other sequence to the other numbers that become other numbers and define our outdoor system and beyond in the bigger details of the numbers in SPF in and paint face and for all I know is that part of other sections have an outstanding amount of information which then is identical to the variety of things in time in time on a compass As a landmark actual location of a planet where is on its own solstice or it’s on August the longest night or split right down the middle twice a year and the same with that’s where the speed of light is incorporated in this anything else in fourths two twins to polar opposites something to that nature. As a landmark actual location of a planet where is on its own solstice or it’s on August the longest night or split right down the middle twice a year and the same with that’s where the speed of light is incorporated in this anything else in fourths two twins to polar opposites something to that nature nature
I don’t know if it doesn’t make sense it doesn’t make sense if you can’t see it you can’t see it if you do let me know soon as a whole bunch more I want to do I don’t sound like such a dumb ***😀 I kind of start to make sense
Honestly don't have a clue about any of your recent postings other than what I posted and that if we've calculated/measured the speed of light accurately we in theory can calculate the lowest resonant frequency in the Universe in octaves, i.e. what real world 'infinite' BW is.
That’s probably very relevant and kind of along the same lines and definitely interesting Often we try to stick out what in the heck is going on in this particular case I put 360 or 345.6 Or 300 in for the speed of sound and the temperature in degrees is a funny number on each of those . t The temperature in degrees Celsius is somehow expressing the speed of light as well as 51.84 is just another harmonic they’re all in line 108 216, 324,432,648,864,972,1296,1728,2592,3456,5184,6912, Every single one of those numbers as a function of another cycle on earth none of which are a parent or obvious they are gigantic cycles much longer than anything dirty equivalent of 72 years to start with one arc second at 72 years that the whole entire procession of the equinox which is 25,920 years will have switched all seasons on the entire planet will have swapped between both sides of the planet in that amount of time none of which are any of us aware of obviously we’re all stuck in the same thing we’re Australia has a summer in the winter and our winter is there vice versa that is entirely different in points of 6480 years along with all those other numbers if you worked them out 1728 obviously that’s how many inches cubedOr in the foot with a net directly correlates to 144 Hz which is also 1440° in phase later same numbers down the line father in the sequence based on the speed of light 12 times in a compound pipe or in Series in Roar and there’s got to be a 13th for whatever reason and it makes sense otherwise it wouldn’t work I guess just like the zodiac horoscope stuff is totally wrong apparently no one’s birthday ever lines up on any of that not even the slightest because of its based on 12 I’m not that extra partWhatever that has to do with I don’t know I just know that you got to do that in this or you don’t get that alignment 860×20 to look at every single one of them -990 DB. 8600 (11) 18920,(22) … There’s a pattern to see and this might stay to make a little bit more sense. If not, Call in the mathematician or the astronomer or some super nerd who will understand this more than a couple of speaker guys try to type back-and-forth
Whatever Tom Danley saw in the pyramids, absolutely beyond a shadow of a doubt is what we’re doing here obviously he can apply the numbers in many different ways three of which are the ones that I discovered in my limited scope of being able to fit them in soon and see results. There is an any other information in the pyramid nor could there be after this this is quite obvious once you see it and it’s also incredibly amazing how that is in there and how in the heck somebody made that like that and then someone can put it in speaker and observe it’s a code or something it’s inside the pyramid in the room dimensions of that room very very specifically all the speed of light over and over again which is 5236 Which is 30° twice it is 60° 90° all of those are represented as well in centimeters or meters inside that room and then duplicate it again and some goofy coughing weird thing that’s not even got a dead body it is just got the same dimensions over and over again in that pyramid that Tom Danley went to and that’s about the time that he kind of started unity or one of those after the tattoo I don’t recall if that’s the right order of when he did that but there’s a YouTube video on this trip and all kinds of information along with the container they made for the military or maybe they didn’t lol,, Which is 30° twice it is 60° 3×90° all of those are represented as well in centimeters or meters inside that room and then duplicate it again and some goofy coughing weird thing that’s not even got a dead body it is just got the same dimensions over and over again in that pyramid that Tom Danley went to and that’s about the time that he kind of started unity or one of those after
Best I could find , there’s is better in parts of documentaries on the subject of the kings chamber those numbers whether you can recognize them or understand them Those are the speed of light as 60 30 15 7.5 and even 75 which then includes 150 to 225 and 300. broken up in a quarter wave parts and logarithmically. Why that’s exactly in a room made out of granite carve into a rectangle to express a circle and in that detail by way of the speed of light is beyond me or anyone? Nevertheless there it is and there’s a speaker we put it in in the same you can turn it up all you want I give you a turd for a driver it’s still functional it’s really something to see or not look atLook at The frequencies of 860+860 and beyond every single one of them to the end of our response there they are. I don’t know why but it’s all exactly the same thing do that math or look it up or get somebody to do it for you it’s kind of a weird twist of numbers in navigational type things arc seconds radians , It’s the quarter wave function split up into a different way I don’t know I had to figure it out and learn it it’s not something you see every day either is that number 5236 I never seen in my life but that number does everything that has anything to do with dimensions of shapes of sphere circles pendulum swing and everything tied into that exact number it covers everything why is it not coming knowledge or something that we all use all the time and this is ridiculous it makes no sense . 30°
Guys I have supplied a SIM for you to scrutinize up and down in any which way possible I don’t need to be anymore cclear or concise or anything other than that . that is all the information anyone would ever need to know anything and that’s how the universe works, that’s how physics works because it’s all right there in that information exactly plain as day I promise you.
Having said that and for the millionth time which has us all equally frustrated trust me, you didn’t design language or numbers or how to share them and neither did I and right now we are trapped in that very thing. I have the luxury of understanding what the hell it is I’m trying to say you have the annoying dilemma of wondering what it is and why this idiot won’t just spell it out and say it.
If I may suggest something it would be if there was anything of any significance that I thought I could continue to pester people about and try to nickel and dime the explanation towards somehow connecting the dots for us all?? It damn well better be something significant and worthwhile or I am a jerk.
So I’m going to leave you with this because there are plenty of other places where am I breaking through here and discovering how this works further and further and can spread it into almost every type of quarter we both speaker design I found where I had to come up with good existing ones Paraflex Roar ask the driver entry transmission line those are all based on one thing and one thing only but your voice is shown an abbreviated form as the odd harmonic. That may well be an excellent exclamation for a location in something. But whatever it is what it is the associate it with the speed of light or pi divided by six or the variety of things with that represents or multiples of it: example 1.0476 in a transmission line that is 299792458cm long will be? A bunch of screwed up decimal points that need to be switched in order to work but that is a relevant as you would see further down the line make that 104.76 and make that 300 put it in the transmission line as the driver and see what happens.
Furthermore what idiosyncrasies and details are required in order for that to actually work seems to me it off a little bit here not a little bit there everything is off a little bit or it’s dead nuts it’s very confusing and that is because of another factor but where do I start explaining that is for spins on for spins on for spins ago.
Phase, frequency, Hertz or million kilometers or million miles these all flip or interchange with each other on the way out and in the golden ratio to infinity golden ratio doesn’t start perfect it takes a long time before you reach the actual 618. Very rapidly do you close in on it from merely .5 all of that and what that means can be seen in the same of a subwoofer the luxury of that being her response gives us frequencies and information far beyond what that subwoofer could even do con break up long before there’s numbers occur nevertheless we now have information that we can only get and verify for real’s at lower frequencies and in the subwoofer. Very rapidly do you close in on it from merely .5 all of that and what that means can be seen in the same of a subwoofer the luxury of that being her response gives us frequencies and information far beyond what that subwoofer could even do con break up long before there’s numbers occur nevertheless we now have information that we can only get and verify for real’s at lower frequencies and in the subwoofer
That information in order to implement it into whatever for whatever reason all of these numbers hover and a gap around 30 which is between the speed of light and pi. If you were to somehow understand what I’m talking about to start looking at it and then Implementing it it on your own accord you wouldn’t fact see this occurring in these ways. This is no doubt one of the biggest hurdles in your understanding of what I’m trying to say and vice versa is it is trapped in a very complex window of change just like that very very slow and gradual teacher I thought the golden ratio in the Fibonacci sequence none of that is represented in ways that make sense until you have to witness it and see it put it this way your speedometer in United States of America is barely even catching up to the sequenced in miles per hours in kilometers but take that a hell of a lot further or towards zero and something similar occurs.
Quarter wave abd making speakers with itIs completely taken for granted and not understood because there’s no way you would ever notice what else is in the information that’s all I can say the rest will just continue to be confusing and create frustration for everyone but I promise you that’s not the intention.
In short as it turns out unknowingly I had put the numbers that are inside the chamber that is a perfect rectangle inside the pyramid of Giza that perfect rectangle in all of his matches in it spell I’ll just circle it is an equation that connects every single thing it’s fears and circles two cubes and rectangles and squares and pendulum swing at an angle all of which represent the speed of light and everything in the universe and if that’s the truth that explains why it does exactly what it does in all this speaker designs. In short as it turns out unknowingly I had put the numbers that are inside the chamber that is a perfect rectangle inside the pyramid of Giza that perfect rectangle in all of his matches in it spell I’ll just circle it is an equation that connects every single thing it’s fears and circles two cubes and rectangles and squares and pendulum swing at an angle all of which represent the speed of light and everything in the universe and if that’s the truth that explains why it does exactly what it does in all this speaker designs Even with the worst driver possible. ???
That’s all I can do and not be wasting everyone’s time anymore I really appreciate all the pointers and all the ideas along the way but there’s no way to pay back but inevitably that produced here and it’s a point I need to shut my mouth and just forget about it because nobody’s going to get it if they haven’t already and that sucks. But it’s not your fault is it mine either however in that is something that is kind of ironic or tragic or I don’t know it’s stuck in human language thing I think we’re not taught a way to not understand because these numbers and the stuff should be universally known and simple it’s merely the parts of a circle around it 30° each 12 of them if you break that down into 48 of them you suddenly start seeing what that means and what those numbers are
There are so many relationships two things and numbers that we can’t see or perceive on the surface they would never even be a parent to any of us but when they suddenly are all my god is it crazy. I found this by coincidence is it dumb pure luck after the fact I can look at it and say oh my god so ridiculously simple that doesn’t however help or do it any justice in trying to explain it what can I say six parts of a circle or 12 parts of the circumference the hexagon the decahedron how does that get us anywhere near 860 Hz repetitively over and over again cancel completely cancel cancel cancel all the way to 19780? this is even a connection there’s a new exclamation you’ve got to observe and all this and come and play with it in the sim. Also got to screw it up and see what it takes to do that and see why it is wherever it is this is not easy this isn’t anything somebody can hold your hand I teach you or show you it’s a one-man show you and your computer. It was twice as hard to figure it out on my end if it is an interesting yet or if it’s frustrating forget it and don’t even worry about it and don’t let it waste your time however if it sounds interesting and it has got you interested genuinely it does produce fruit it is worth it at some point I just hope that isn’t far far away I’m talking a long long time before I even put two into together let alone 860 or 19780… Those numbers are because of the speed of light speed of light 30 cm the speed of light .5238 the speed of light doubled is 104.76+ different ways of putting it in different types of quarter pipes I have no explanation for that no way to explain why the variety of different ways and methods of make it work I know of is this the speed of light and it works on everything already so there you go it’s an anomaly in that regard but it isn’t in reality that is some serious ironic duality mirrorAwkwardly wow moment in one’s own capacity to think . but see how this works if you understand speakers in true quarter wave with (transmission line??) it’s a horrible name that means nothing nothing at all however we’re stuck with it. whatever you wanna call him at a level that you can put us in a minute and see it function and offset driver capacity and then there’s other ways you will understand completely what the’ fawk’ ?? moment that this creates when you see it and how you see it works using different numbers yet in a different layout of a transmission line with a special feature a roar a compound para flex with a driver entry position eight offset driver transmission line speaker with the driver entry position that’s what we’re talking about here driver entry driver entry driver entry and exit pi divided by six.
I have yet to understand why there are more numbers for the auto harmonics besides the 03492 which I can associate with and also make that into 05238 because it’s 104.76 cm in 300 where that occurs take that and use it in other ways that’s all I can say I’m sure the rest is even more confusing be a good place to pause because just two days ago myself and another guy discovered another way it works in another design and I’m sure it’s going to show it’s just another version of the speed of light in some form of mass or degrees around a circle…
Because then it solves everything study a cube and study a hexagon an isometric grab paper and tell me what they look like the same thing that speaks volumes in math and just because it looks like the same thing doesn’t mean it doesn’t do the same thing in math you can break that up into triangles put it on a circle the edges that touch the circle or five or six or five and six and 12 parts it makes 360° did also makes 30 (or five or six) and The ark is outside of that flat edge of the hexagon that you put that on. The arc outside of that five on the side is now 5238 slightly longer it’s an ark if that side was 30 the ark would be pie 3.14 if that arc can you tin you to grow it would be an entire circle but in that one increment of 30 it was 3.141 whatever is there at 5 or is that at five on six because that matters. that you have to draw and explain yourself and figure out there’s no words for that I said another circle another layer in That math.
Start drawing is the only way that’s always been the truth people just got to conveniently spoiled by assume that does all the work for you guess what happens when you do real work and figure out what things are and then you put that information in the same that is something to consider because none of us ever do we rely on the same to tell us everything and it does but you wouldn’t believe what it tells you when you give it information that’s real that’s him becomes the answer to anything. Remember what we are simulating remember what that is all about understand that those things are how the entire universe works frequency distance you name it if you put real numbers Internet seem that represent real things you get really really really good answers. That’s not something that I can explain or present in a way that is going to make sense ever nor could anyone. But the more people who know in the more people who look the more people will find us in sooner or later we will all understand and we will all be able to make the very best speakers possible because they look at what they will be based on think about it don’t get pissed off at me get pissed off at the world that didn’t teach us the simple numbers that are inside the pyramid of Giza all the time always happen and thank David McBean because there’s no way any of this would be happening without him but there is absolutely things to see and do in fine far beyond whatever it is you’re building now and at what point it is just so good or not so good quite possibly could be very much improved if it can use a few numbers
There’s a list of numbers which are describing a circle which then also I have numbers in radians deck put into quarter wave allows you to see positions to do things instead of just a long vent that means nothing from start to finish in between is left random and why nobody even cares where they fold yet that inevitably and increasingly so very much shows up as soon as you compound the issue or higher order the issue. I’ll be speaking to the choir or preaching to the choir but if you don’t start folding where there’s already a start or stop inherently I E a harmonic pressure phase node you’ve interrupted the system where it already provided you with an interruption that you were supposed to take advantage of if you’re already using that idea to build a path. If you’re making a horn with a flat rate if you’re making a base reflect speaker if you’re doing any number of variety of other things I no doubt don’t think that any of this will never make any senseHowever it’s becoming increasingly obvious that they are all connected in a way that says flare rate and flavoring is not exactly ideal ever in anyway don’t mean that exactly I’m just trying to narrow down how to explain this all much easier pipe can expand at certain points and not drop things out of phase not screw things up not do all these things and we’re talking about phase at the level of 30° 7.5° nitpicky stuff do you not even be concerned with but that’s where the numbers start up because that’s where the speed of light begins to engage in the math. 7.5m15, 22.5,30…Ironically those are slightly off the speed of light take the speed of light always a decimal point divided up by four parts you’ll get 749 you get 2249 you’ll get to 99 etc. etc. that very thing shows up far far away do you want more even talking about again in numbers the number 11 versus 10, is the most grossly exaggerated version of what numbers and everything is actually doing in the universe so it would seem to me because of the math
Do I explain why the speed of light and why that number or do I just give you a bunch of random numbers here look at him and you go OK so what that looks like a pretty good sale it’s kind of cool so what do I care?! That’s exactly what would happen and then that’s it nothing else will be understood looked at or considered that’s really weird that’s what happened to the Egyptian pyramid forever what’s inside and what does that mean what are all those numbers concern anyone with I believe I was trying to picture of that and show that as well what does numbers are if anyone still interested it’s not causing any trouble we keep going with this I just don’t wanna be a problem or creator of frustration in anyway I wanted to somehow figure out a way to share this so that you could take it and use it in your own stuff because I can I can barely find where it doesn’t explode into something perfect if that’s a word for whatever reason how do you split up a circle in the 12 person you ever met her in speaker parts it matters you can see that if you divide 6.2857142857142 into 12 or 48 parts or divide 360 into 1248 parts that all That’s all matters how to say now stick it in the speaker is 3060 9180 parts and how to do that at some point you’ll see the pattern and it won’t matter because you’ll never go to 30 all the time for driver entry or 60 but that’s not 60 any longer it’s the other version of the number that is crystal clear if you use a 300 cm long transmission line it becomes 60 as 104.76 the units have converted the effect is the same that’s why the reason why so peculiar peculiarAnd obviously why it’s so hard to explain I just hope that obvious becomes obvious on your end sooner than later because I understand the frustration and I apologize it is however worth it somehow someway to see
@ Booger weldz: please try harder to be concise and a LOT more TO THE POINT!!
Also I’m struggling to connect the dots between sub closure design and the speed of light.
Let’s try to connect these dots. Its just throwing darts at a dartboard waiting for somebody to pick up on part of it so then it can be expanded upon from there .
Let’s assume that somehow there’s a way to align both sides of the drivers output either in Series or in parallel to combination exit which is not unlike the infamous offset driver location on automatic transmission line. However in this case we’re doing something like that to both sides on the short side it’s in the same exact location it would be a standard transmission mount on the long side it isn’t however it does match the distance from the clothes and chairs with the opposite side , The difference being between the two of those there’s an additional legs which makes the long side 270 cm in the short side 90 cm both of which have a driver 30 cm from zero so to speak ,and an 30 cm exit that they share at S4 response PH one mode.
Given a constant CSA throughout at this point although that can change in a very specific location and we can get to that if we Given a constant CSA throughout at this point although that can change in a very specific location and we can get to that, So now we need that exit to be the storm of three of the CSA used in the actual qw pipe(s) . I don’t know what we can call it but the short pipe is the length Of the pressure wave node in the longer one as 3 x 1/4 harmonic .
In the sim it will look like (30 150 90 )and (30/30/30 ) . For both sided as s1-s4 and S 6- S9 30 more as L45.
Take a look then at 860 hurts acoustic power screen where you get a smaller or detailed screen numbers on. And check 19780, 8600., they all say -990 DB and if so then every single frequency at that interval will as well. If we can establish that maybe we can talk about what the heck is going on and what does the numbers are and what they represent because it very rapidly because increasingly interesting watch that established
Hopefully we can get there and see the Strange and interesting things here
