Pictures of your diy Pass amplifier
to starcat
Had to search for 'Dartzeel' - didn't know the brand
I have done this a few times - frame construction with aluminum profiles...
Cheers
Dirk
Dirk,
Nice work as usual... you are an expert in putting the aluminum profiles to good use. 🙂
A question on that - do you order the profiles according to specific lengths or cut them yourself? If you are cutting them by yourself, what are you using?
to codyt #6101
Good morning,
yes, it is tinted plexiglas on the Backside of my BA-1 - Monoblocks.
I like translucent grey. If the amp is off, it looks like black - if the amp is on
you have a blue shining 'UFO' in your listening room. 😉
Cheers
Dirk 😀
Reactions: Stefano
to zman01 #6110
Good morning zman01,
I buy the profiles from a distributor here in Germany cut to length.
They are offered in 10 cm-steps/ length. You can order them customized
for a little extra costs.
Cutting them yourself is possible with the right tools - but no fun. You need
a good miter saw. Aluminum profiles flying around in your working area is no fun.
Cheers
Dirk 😀
to mordikai #6115
Hello mordikai,
the aluminum - handles are normally used in mechanical engineering.
Often used at the control panels/cases of machines.
I am searching for them at the moment. Because I also need 4 handles
for the new build. But they seem to be not availible in aluminum at the moment.
You can get those handles also in plastic - but I don't like it.
I am searching for the distributor and will post it here or I send you a pm.
Cheers
Dirk 😀
Good morning,
Cheers
Dirk 😀
it took me some efforts to go back and view all pics ( and ZM is not used on efforts)
so, Fugly!
:clown:
to Eric #6108
Hello Eric,
the PSU seems robust enough...
Sometimes I do tests how rigid / robust the frames are.
Although I have posted those pics before - again for your entertainment.
The 'Fakir'-test on the new build and the handstand-test on the 50W-SE-Schade-amps - some time ago.
Please don't do this!!! 😱
Cheers
Dirk😀
