DIY ACA mini
Great idea.
I’ll probably build mine on top of some nice stained wood, 6”x6” should do it, a bit like the pic below which is for a small tube amp.
BR
Eric
Codyt, any possibility you might make some single chanel boards ? I asked earlier if this amp would work with laterals and Nelson said go for it so I was thinking of building this amp in a gutted Halfler DH220 case. I figure having a negative temperature coeficent I wouldn't even need the source reistors if I used laterals.
The old DH-220 case is a perfect size for this amp. If you have a set of the Hafler matched lateral Mosfets, you can leave them installed in the heatsink flanges. (Clean and apply fresh thermal grease.) The laterals will need a lower Vds to turn on, and can certainly get by with less source resistance.
I hadn’t really considered doing a layout for the circuit itself, but who knows. That said, Jim’s suggestion is a good one.
Hitachi is going to be just warm, Hafler not even that
in any case - both of these better to combine (using original mains xformer and outputs) with latest Stasis FE and make big amps
for this mini ACA , small case is part of the game ........ and both of these are just .... not important being overkill, but being clumsy in size ....... not cute anymore
of course, just my opinion ( but we all know that my opinion is only truth)
:clown:
dunno mate
I'm certainly not lacking projects in progress, and that one is awaiting proper moment of lunacy .......... what is important is that I disassembled functional amp in pieces long ago and it is just waiting
no biggie, it sounded as crap anyway :clown:
edit: is it thing to worry about - I'm still immensely enjoying wild disassembly :rofl:
Got mine today. Unfortunately, I’m off to travel to Albuquerque to see the ballet this weekend, so no time to build. Work still interrupts my days, so this little project will have to wait until next weekend (or some evening this week if I can muster the focus).
Looks like it will be fun!
Dang, this thing sounds good! Thanks again to Nelson and BAF for the opportunity to win and build one of these.
So far I’m preferring the jumper in. Really fun to change on the fly! Hope to makes some measurements soon.
