$360 for a hole...?
Hello everyone,
I was reading on the forum until late last night about how I can punch a rectangular hole in a piece of sheet metal. To be specific, I'm talking about the sheet metal used in the Hifi2000/DIYAudioShop Pesante chassis. (My ultimate questions are highlighted below.)
I've had the electrical portion of my design project done since last year, and I set out on the task to finish the job, but Hifi2000 says they can't mill/drill/punch/etc. the steel they use in the Pesante rear, side, top, and bottom panels. I have a Schurter AC supply socket that I want to use, but it is bigger than the simple IEC panel cut-outs they offer. I also want to be able to hide the power switch that I selected on the bottom panel of the amp on the front right side.
From what I read here, the "best" solution is to find a Greenlee knockout punch. The knock-out that is closest in size to my power switch is $360. That is a very expensive hole. I also tried to find the q-max punch mentioned, but I was unsuccessful in finding one of an appropriate size. Does anyone have a link to their website? Searching for "qmax" in A LOT of results. I would need still a different size punch for the power cable connector.
Is there a type of professional shop that I can look for that might have these types of tools and could do this for me? I will also need drilling of round holes for I/O in the back panel and holes for mounting the feet in the bottom panel. What kind of shop would have a CNC that can mill 1 mm steel?
Jeff
Patience, my young padawan. With drills and files, make holes, you will.
For a one off?
Change the socket!
Before CNC became common, there was a method called chain drilling, you drilled overlapping holes along the path, then filed to shape.
Tedious, on press tools with High Carbon High Chromium steel, complex shapes.
Wire EDM took a lot of the tedium away...
You can do 1 mm steel with a jig saw as well.
That $360 tool will make thousands of holes, it is designed to be used on a press of the right size.
Add shipping, and machine time, and setup spoilage, and you are looking at much more than the tool cost.
Not worth the hassle for a single hole.
I would just settle for a small round switch that is easy to drill.
For the switch, I'm seriously considering buying a different one since it will be hidden on the bottom. I may also use the one that I have and move it to the faceplate, which is aluminum and can be easily milled. Just wasn't the aesthetic that I was hoping for.
Do you need to use a drill press with this method? I have only a couple of handheld drills. If I have to, I will try this method. My skills with hand tools aren't the best. 🙂
If you have handheld tools it can be easier to not overlap the holes, otherwise the bit will fall into the one next to it half way down and you'll have a mess. It only means you'll need to cut between them afterward.
The Electronics side is "easy", "mechanicals" is the curse of the DIYer.
I started making Guitar amps in 1969 and exclusively used Aluminum which is easy to work on, and needs no treatment since it does not rust, I HATE steel sheet with a passion.
From the very beginning used 95% round holes which can be drilled, and bought two Greenlee punch copies , one for chassis mount Fuse holders, another for Noval sockets.
Used them to death and they are still in some tool box.
Octal socket holes were cut with a cup saw.
For the odd rectangular switch hole (which I avoided if possible): couple round holes and a file.
No CNC, water jet, Laser available in the 70s to 90s and machine shops asked for "100 of each" minimum orders, lots of 500 preferred, so .....
