I have never looked closely at that, just enuff to know it is rehash of the work Olson did, work that impacted the midPod development.
But the formulas (empirical) might provr useful.
The basic first formula is BS(-3) = 4560/baffle width in inches. The ideal target for supraBaffle width would be close to = BS(-3)/0.707. With the goal LF target somewhere between about 300-350 Hz. That might prove large.
dave
dave
Considering 300 Hz, it's 15.2 inches or 39 cm. This is the side of the square, or the diameter of the circle if the supraBaffle won't be squared.
To have a similar width of the deflector, the side of the triangle needs to be around 55cm long.
Bigger than i would do. The blue is as small as i’d go, it gives just enuff coverage to put some pod bits on the side & top (i’m looking at the ellipse). Anywhere between the 2, get to close to yours you are pushing your luck.
The dotted line represents what i would consider a minimum size. The deflector pushes the horn moiuth out from the wall. You don’t want to push it out more than wher eit is comfortable bass wize without.
If you are considering a woofer, width is often determined by how much volume you need. It is tall enuff to be a short, wend loaded ML-TL.
dave
dave
Thanks Dave,
could it be that the front baffle, instead of being rectangular, has the shape as in the left (diameter chosen to let the rear parts be mounted without modifications), and then behind that baffle the width goes as wide as the 390mm deflector (as in the right)? Or being "supra" Baffle, it must be mounted on top of the front baffle?
I forgot one point: would you use the deflector as end loaded ML-TL woofer?
By now I'd just use it as deflector, because I would like to avoid crossovers on these speakers, but keep the possibility to add it in the future.
I would like to ideally install the speakers around 8-10 inches (20-25 cm) from the rear wall, on the sides of the fireplace, around 10 feet (3 meters) from each other, pointing just in front of the sofa.
Exploration of supraBaffle is still in its infancy. Play.
The goal to smooth the 2π to 4π transition, and push where it happens down.
Where it needs to take effect will depend somewhat on room & placement, the B&W pod (and the Eclipse) suggest the best shapes to smooth things out. The trailing edge is as important as the front.
dave
dave
I've seen this page: TD510MK2 Unparalleled performance | ECLIPSE Home Audio Systems
I can try to ask to a friend of mine to model something similar on his 3D printer, but honestly I would not even know hot to determine the internal volume and reflex pipe.
What I can try to do is to see if I can inscribe the FHXL into the egg shaped B&W pod and Eclipse. ...but I would say first of all start building the FHXL as they are, with that 390 mm wide deflector.
It is important that the leading and trailing edge are smooth. A cylinder is not a good shape.
Note that this reseacrh is some 7 decade sold, B&W’s pod grows on it.
dave
dave
Hi Dave,
joining B&W and FHXL, how can a drop-like B&W be installed on top of the FHXL and "connected" to its horn?
Doesn’t need to be connected to the horn. The rectangular corners of the FH will stick out the back of the teardrop.
dave
dave
Sorry Dave, I've not explained my point well.
I mean having something like that on top of the FH:
The same way here there was a ball:
It must be connected to the horn to get advantage from it.
The placement of the driver cannot be changed.
The pod has to be imbedded in the exsiting top of the box.
The sphere on top of the FH1 that you have shown is a very different situation being an end-loaded horn with an ir cavity and not a tapped horn s the current FH generation are.
dave
dave
Finally got mine finished! I honestly forgot how good these sound... I really don't like sapele but it was what I had lying around, and good practice for veneering. I have a lot of woodworking experience and I've found veneer to be challenging but I think I have the hang of it. Next time I will plan to splurge for adhesive backed. I used the contact cement method for another pair and it rippled (could be due to saturating it with waterlox, probably should have wiped that on), this time I used titebond and iron and it went okay but a few small bubbles. I used a black gel stain on the sides, and put magnets under the veneer so they can be used without the grills.
Pass DIY Addict
Joined 2000
Another set just finished! Must say that I’m impressed. I built a pair of Decware DNAs several years ago and loved the sound of the 10P in them. The FHXL has more bass, I’m running mine uncompensated, where I have to add about 3db bass boost to the DNAs. The big difference I see is the bass of the FHXL is more dynamic. Faster if you will. More impact. I’m still trying to decide but I think the DNAs will reach lower, into subsonics. I don’t have much listening time yet with the Frugels but the bass in a song or two seemed to be “confused”. I believe it to be a reflection issue and will play with positioning before I badmouth the speaker. I’m running 40 grams of well teased poly upstream and currently nothing downstream. I used veneer that I had left over, curly maple and walnut, the walnut was too short to just run vertical so I cut strips and put them together at an angle. Frugal. Or cheap, but I like the outcome. I did burn through the veneer to the paper backing in one spot, anybody know of a way to fix it? Because of the current price of Baltic Birch, I used 9 ply Samauma instead. No voids and $44 a sheet. Also, if you don’t mind the grain of the internal divider running cross instead of up/down, you can get everything but the top out of a single sheet. As an aside, I found the plans for these “in the wild” but still donated my $10 if anybody cares. Just a heads up that they are loose.
Pass DIY Addict
Joined 2000
- Full Range
- Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more
