10F/8424 & RS225-8 FAST / WAW Ref Monitor
Hi Potstip,
Here are some more photos. I’ll show you all that I have as we go. Here are some more. The poly fill damping is pretty straightforward. Fill closed end to the top of the speaker at the 180deg turn. Adjust to taste or by taking impedance sweeps with a DATS. Approximate volume of poly fill same as two size No 5 soccer balls. If bass sounds too boomy, add more.
Hello x;
Please see the link here below for the pictures;
I tryed to identify the surfaces for egg foam and spaces/zones for the poly fill.
Can you confirm if it is correct?
Spk - Google Drive
Joined 2021
Some progress here - still waiting for the ply -, xo is ready :)
Founder of XSA-Labs
Joined 2012
Hello x;
Spk - Google Drive
Yes, that looks great. You can conserve some foam by only covering at least 2 walls on the long vertical run down the back. But what you have is fine.
