Looking for a good not expensive streamer
Corporations use them extensively and when they get replaced at the end of their warranty, the used/refurbished sellers get flooded with that particular model, driving the price low. They are built to last (including properly-designed power adapters), often nice-looking, decently equipped (USB3, gigabit ethernet). Some have options for multiple SSDs which can be handy for inexpensive raid1 https://www.diyaudio.com/forums/digital-source/377502-external-ssd-music-storage-6.html#post6808144
The older models are too underpowered for running graphical Windows (CPU and drive space), but for headless linux they have plenty of power and space (1GB RAM, 4GB SSD is enough).
Some 5 years ago I built a simple streamer/CD player/amp with FS Futro S450/550 (20EUR from ebay.de at that time including the power brick) Home * pavhofman/plabs-player Wiki * GitHub, it has been running basically every day since then in my parents' kitchen (close to the stove, a bit demanding environment) and never had a single failure.
OT question - just got hit!
Fired up the AP and the Apwin 3.3 software and got an error message from the runtime library it seems, see attached.
What I did:
Ran Apwin in demo mode, no AP hardware powered up, no USB connected: same message.
Repaired the latest C++ runtime's I found in the Settings|Apps: same message.
Uninstalled Apwin, restarted the PC, installed Apwin: same message.
Apwin runs fine on my other PCs, and it ran fine on this one until just now. What the heck?
Any ideas?
Jan
I don't know which version of the runtime is needed. And there is no update to Apwin, for at least 5 years ;-)
It is intriguing that this just happen out of the blue, on this particular PC only.
Thinking about the error message, it doesn't appear it is the runtime, apparently the app (Apwin) requested to the runtime to terminate it, in an unusual manner. Hmmm.
When I launch the app, it says, can't find hardware, you want to run demo? Yes, then it brings up de screen, the analyzer panel, the generator panel, next should be the sweep panel but then it quits.
Jan
Got a new iFi Zen Streamer. Install via the app went well, until at the very end. Then I get the rotating circles (busy) and the text https://ifi.local/
I've talked to their service desk, no immediate solution, send in a support ticket, but that will take some days for a reaction.
Any Zen Streamer users here have an idea what is happening and how I can fix it? I can send it back for a refund again, but in the end I'd just want a working streamer!
Jan
So I went to the update function, and yes there was a newer firmware and I started the download. It ran until 50% then stuck there for 5 minutes. In despair I closed the browser, opened again and the thing was totally unresponsive, half of the menu's weren't there, no play list, what have I done!
Tried again 10 minutes later, all was well, and the new firmware was installed. So it looks that the internals are fine, except they seem set to scare the user whatever he does! Get a grip guys!
Jan
