GB: Round #8; Fo-Felix AC Filter
I checked with supplier of terminals, estimated ship date is 9/16 . A little disappointed on that time frame... what's new. I'm over the covid stuff, let's ship things again.
Not surprised at all, and it could certainly be worse. It's been such a PITA to get parts. The shipping container shortage and gouging will likely be around into next year. Just have to suck it up for now.
Standoff kit for this board
Hi
I will be mounting this project in an aluminum case. I was wondering if anybody can suggest a suitable standoff spacer and screws for this board?
Destroyer OS notes that the board works well with "M3 screws and standoff kits."
I am looking for a height of less than 8mm for this. As usual digikey has too many options for the nonexpert to make sense of.
Thanks for any leads or part #s .
The boards are isolated from a short circuit unless you some how stocked progressively larger star washers until they were absurd and continued to wrench down super hard on them. You can see the gap on the boards when looking at them.
Stands offs can have a double opening or a stud on one end. So if you want the stand off to not need a nut or a screw coming from the bottom, yes you'd have to tap the enclosure.
