These in the sense similar, made for Philips in China, the rest of the work is done here.
Older designs had a separate LED board and driver board...and cheaper designs used RC networks to drive the LEDs!
I can see the members from more advanced countries rolling their eyes...
NareshBrd, you seem well informed about these LED bulbs.
Mine is a broken Tesco 8.5W 2700K. It refuses to glow.
Using sophisticated tools I have disassembled successfully and now just need advice on where I obtain a new yellow coil before gluing it back together. 😎
The yellow coil is clearly split and broken apart. 😱
I suspect it is the INTEROCITOR coil. I would further guess, as a layman, the overall device is an "interocitor incorporating electron sorter" and "intensifier disk" combined. But could be wrong. 😀
That is a Ferrite transformer, the old designs were like that: separate driver and LED boards. In a 9 Watt, the supply is constant current 27V.
For 20p I would not bother, just keep aside for when another pops with a different fault. Then mix and match...check that the LEDs are OK.
I have supplied LED flood lights, bulbs, panel lights, and filament LEDs as a trader, and have had a reputable run, because I sold A quality material, with wide band supplies and surge protection.
Here the government had a subsidy scheme, gave millions of bulbs at cheap prices to users, with a three year replacement guarantee.
Poor people could make part payment over six months.
So these suppliers were in contact with my importers, and I had knowledge about what was happening.
Supermarket price for 9 watt bulb is less than 100 Rupees, Philips T bulb is 10 Watts, about 150 Rupees.
1 Rupee is about 1 UK penny at this time.
Closer inspection of the coil reveals it looks like some vandal in the factory sawed through it with a hacksaw!
Can't imagine how else it happened... 😱
Think I'll just give up. 😡
You didn’t read/heed the “no user serviceable parts inside” warning?
LOL!
Actually that's my avatar!
I prefer this 😀
I have some Phillips, but most of my LED lights are 4$ Chinese from eBay. Never had one fail in 5 years not that they are lit up a lot.
My main lights are now "Smart" bulbs that can be RGB, Warm, cold, or a blend between warm/cold. These ones are 12$ a piece but I can turn off the lights from another country lol
They are cold in the day, warm 30 minutes before sunset, and the I turn them red at night.
I prefer this 😀
Jeez!.... what sort of place is that?
You running a line of hookers outa that joint at night? 😱
Yeah right... people watch television in the red light district of Toronto... 🙄
I think wiseoldtech has sussed you out, matey. We know your game! 😀
I have found a light that is entirely user serviceable, and parts freely available.
No, I don't make this up. 😀
Phoebus cartel...I'd think likely, the same sort of thing is ongoing within the new LED stuff we see now. Ask yourself, of any and all our gear, have you noted a single burn't out LED? A power indicator?, stereo indicator? peak indicator?...anything? And no, I'm not referring to the ancillary drivers...
"30,000 hrs expected lifetime"...I call BS.
----------------------------------------------------------------------------Rick...
The electrolytic pickle will eventually dry out and quit working, and somehow I think it will quit long before the 2000 hour rated life of a cheap electrolytic cap used in the power supply of an LED lamp.
The Electric Pickle Lamp turns out to have some teething problems. Apart from a very flickery light, the pickle stinks in operation, and the pickle tastes plain awful after lighting employ. Ah well. 🙁
Investigations of the failed 9.5W lamp have been ongoing and illuminating. I ripped the board out with pliers.
It seems heat is the factor that shortens LED bulbs life. The small electrolytics are rated at 400V and 130C, and we know they conk out quicker when hot.
And they do get hot. But my guess is a small soldering fault on one of the 8 pin SMD components. Two pins had a stray solder blob shorting them.
We might speculate that this fault, whilst not fatal to initial operation, caused overheating or failure elsewhere.
I could conceivably get my money back on a manufacturing fault under warranty, but have lost the receipt, Additionally, Tesco's lawyers would doubtless claim that opening the device invalidated my warranty. 😡
20 interesting facts about LEDs:
20 Interesting LED Facts Everyone Should Know! | JimOnLight
System7's (steve's) post above is veeery interesting, and the link to the 20 interesting facts is also a good read.
Particularly item #12.
I 'll have to mention that to my neighbor - he's got a string of small incandescent bulbs (mood lighting) around his porch, and when we sit out in the evenings enjoying beers conversation and music, those night-time bugs can be a bit annoying.
Like last night.... ladybugs, moths, and other assorted flying creatures stopping by.
I always though the multi-color bulbs could be used for home automation signaling purposes. Solid red could indicate something needs to be tended to, or there's an intruder lurking about outside...
When we used to sit outside up north, we'd put on a really bright light about 50 feet from where we were sitting.
One night we got to have a game of "how many of these moths can we beat out of the sky with pool noodles?"
So we got to it and stood there bashing them until we got bored and went inside. The next morning we say just how many we hit LOL There were thousands of dead moths on the ground around that porch light.
PETA come in please.
Not many will recall that one. The cartel everyone thought of, discarded the silly thought ... but that turned out to have existed from 1925 to 1939.
The LED drivers even of pro stuff don't last as they should. I know them from large quantities in supermarkets where replacing them is a day job over the various locations.
Phoebus cartel...
- Member Areas
- The Lounge
- What did you last repair?
