Aleph J illustrated build guide
Could be a hot spot developing somewhere.... Typical places are lug connectors and screw terminal blocks and/or bad PCB solder joints, where DC rail wires leave/enter PCB's. We are talking some 3-4 A of constant current here, and that can cause a lot of heat across poor connections with high contact resistance... worth checking.
Got one of these:
https://www.amazon.com/gp/product/B01LVW4SLP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
So far no issues....
These (babysitters) are certainly useful once the amp is flawless. But I’d triple-check everything is good before using such a jig (and not use it to cool down something that overheats because something might be not proper. )
Good point. I did run it once without any additional cooling and it worked fine for 2 or 3 hours.
I think the issue might be that I installed the MOSFETs at the end of the heatsink, so heat dissipation is not optimal.
Other than that, I have checked and could not find anything abnormal.
DC offset is pretty stable for a DC coupled circuit, as is the bias moving a few milivolts up or down.
I don’t get it. The temps you posted should pose no problems, unless real life values are higher than what you measured, I always push it further than that, with the only reward being better sound, and increased risk of imminent meltdown. I agree with Myleftear in that you should not stop searching for the problem. Pics would be good if you choose that approach and need advise/tips from the forum.
Hunch? I would say it is rather a JFET/gain stage issue than an output MOSFET related problem.
Andy
Following on the theory you mention that it might be the frontend, do you have any suggestions on how to go about it to prove it or discard it?
I haven’t built the J myself. Work is in progress with the J Zen, but this nevertheless means I am not extremely familiar with this particular circuit - hands on at least.
But to solicit relevant help/advice, I would recommend you do the following:
1: Post pics of the PCB on the problem channel.
2: Confirm that a) All resistors were measured before installing, b) All solder joints look good, and c) all flux residue is cleaned off, and d) confirm your source for the JFETs used.
This will be a good start, and there are plenty of people active in this thread that will jump to help you once pics and relevant info is in place.
Andy
Q re transformer leads
I am about to wire up the first mono block in my Aleph J build. I am using Avel Lindberg 250VA transformers. The leads on the transformers are tinned. (See attachment.) My plan is to use crimp connectors (circular and snap on) on the leads. However, I have a vague recollection that one should not tin the wires when using crimp connectors. Is my recollection correct? If so, should I remove the tin before crimping?
Thank you for any assistance anyone can provide.
Jazzzman
Far behind. But finally dismantled my BA-3 today, saving the boards for later tinkering and upgrades.
Seen here don’t look like much, and probably aint much, but managed to fasten the rubber feet through the bottom plate and heatsink frame by drilling the holes larger. Also included is ZM style spacers which I managed to mount using a star M3 screw into the sunk in hole - so that the screws are clear of the bottom plates. Spacers are standard China stuff, and a washer helps stabilize it.
Slooowly, but steady.
No boards arrived yet, but the PCB spacers have found their place in the sinks, Poseidonsvoice style, which happened to be my plan too.
Andy
I tried your method but M3 stands seems too thin to me for donuts weight...
I put a washer right under the spacer to stabilize, and also I put in a third spacer per side - in the middle point (see pic). I expect it to carry a dual mono with 2x300, 12 porn caps and 4 x 2.5 pound inductors. They seem not to hold, or tested?
Unless you are using this? Google bilderesultat
:rofl:
Jokes aside: ZM’s approach is probably far more stable. A bolt and towered nuts to achieve desired height. Gonna try my way, and if it fails, Mightys way. I had many spacers on hand, so…
Btw your build progress looks fantastic!
