18" sealed sub of modest dimensions
Hi all I am hoping to build a sub for Home Cinema to work alongside 3 existing subs to fill in the bass below 18HZ and smooth the response around 25 Hz, the other subs are EQ'd and aligned and I will EQ this sub and integrate into the group
BUT, it does need to be something like 550x550x650 external or less. I have been experimenting with some models looking at different drivers and wanted to see if any advice could be sought here 😉
IWC,
Of course you didn't mention how thick your enclosure walls are or bracing, but no worries.
Your external dimensions dictate a 6.94 cubic foot box.
A BMS 18n862 would be wonderful in a 4-6 cubic foot box with tremendously clean bass, particularly midbass to boot.
More information and testing here:
Data-Bass: Subwoofer Measurements
You can buy the driver in Europe at: https://www.lean-business.co.uk/esh...-p-2581.html?zenid=rdpnb83spsfosskiq9npe8k9g0
There are other great drivers that are 18 inches in diameter but this one has been extensively tested, tried and measured. I am also a fan of B&C, La Voce, Faital Pro, Dayton Audio etc...
B&C TBW100
LaVoce SAN184.03
Dayton Audio UM18-22
Dayton Audio RSS460-HO
to name a few.
If you are in the US I would point you to MartySubs' website as it takes all the guess work out of building the enclosure (although most of what i have seen there are ported/bass reflex).
Best,
Anand.
Dayton UM18-22 is a great value for 22mm of Xmax.
I've used it in a sealed box of about 6 cubic ft.
Data-bass.com has a good test of it in a sealed cabinet of that size.
Compared to the BMS18n862, the data there show the UM18-22 to be few dB higher around 20-30hz and a few dB lower around 60-80hz.
Your original post suggested that you need output at 20hz and below.
The UM18 has a lower Fs and is actually about 3db more efficient below 35hz than the BMS. Above 35hz it's a totally different different story however...
At 20hz, a 6 cu ft box and 500W will get you 103dB from the BMS and 106dB from the Dayton, according to winISD. At 40hz they are roughly equal, at 80hz the BMS has a 6db advantage.
Here is the plot of my current output using the average of each channel in a 7.3.0 set up (I have manually followed a Harmon curve and only EQ the subs). The subs are three Sonus Faber Cremona which are 12” with 2 passive radiator units quite heavy - 36kg and not much output below 18HZ, I have EQd and time aligned and the bass from 30Hz up I have plenty of headroom (I use all the speakers full range and add in any bass shortfall with a 10x10 mini dsp) I have also loaded the subs shown across a 2m wide seating position as well, this was taken 12m ago and I have flattened a bit further since
It’s the recognition that a 4th sub placed in the front left corner could be easily fitted and the REW simulation supports a good response around 20Hz plus it smooths my 25 Hz null. I have managed to get the three subs to provide a very consistent response across the seating area, so hopefully I can rework the same methodology with 4 subs
I also want to use my spare BK amp “only 500W with 1000w peaks” it does have a meaty power supply and it was a notable upgrade when I bypassed the existing plate amps in the Cremonas, pic below of the difference and the BK amp in ints separate box from underneath BSBPV500
Looking at the Dayton vs the B&C in an approximate enclosure size measuring I have decided longer could work so using external 700x520x520 which give an internal volume of 147 litres
These are the curves looking at the two, because of efficiency the B&C and how it might look with EQ it might work better ? B&C Green 95-98db, Dayton red 86db
I hear you but looking at a 2 cubic foot enclosure and only 500W I am way down on the db at 10 Hz vs the B&C and marginally better by 6db 20Hz.
Green 15" (only one) 500W
Red B&C 18" 500W
Blue 15" (only one) 3500W
😀 Nobody understand Swedish in Norway
Isn’t it the other way around? 😛
Interesting thread, I’m looking for a 18” PA sub for small box myself. I don’t necessarily need the highest SPL but I just like the sound of PA bass, tight and strong where bass guitars and drums doesn’t just sound like a fart, modern home theater subs sounds awful to me with their extreme xmax. High sensitive driver is a bonus but I understand low Fs heavy cone is probably more important to get any lowend from a small box but hopefully an 18” doesn’t need to have such wild Xmax? I’m actually thinking more of a 80l cab. Many pro subs are quite small. Not sure how they do it.
Example: Delta 18B | Wharfedale Pro - Sound Reinforcement and Live Sound Equipment
Is it this driver?
https://www.eminence.com/pdf/Delta_Pro_18A.pdf
It has a tiny magnet though.
