That's what I used to think too Charles. Sprinkler yes, bubbles no. A diver told me the truth. Bubbles used primarily during training for when things go wrong. It hurts less.
EDIT: Galu beat me to it.
The sprinklers or bubbles are there so the diver can see the surface and so time their dive properly.
Have to disagree. I saw it on Nova or some similar program.
Giga is always decimal, in this case 1GB = 10^9 bytes. The binary multiple 2^10 is 1024 has the prefix Kibi.., and multiples are Mebi.., Gibi... Examples are 1024 bits = 1Kibit (long form 1 kibibit), 1024 Kibits = 1 Mibit (long form 1 mebibit), 1024 Mibits = 1 Gibit (long form 1 gibibit), etc.And then there's gigabytes (and megabytes). Do the prefixes mean 1000 or 1024?
So if you buy a pendrive of 64GB capacity, it turns out it has less capacity in bytes than you expect...
The unit for voltage is named after Alessandro Volta, and the symbol is V. The German contributed much to the theory of electricity, and called it "Unterschied" (difference), hence the other frequently used symbol U.The U for voltage is another story 🙂 As all stuff was started in Europa things became named often in the language of the founder which could be any European country. The unit name often being derived from the name of the founder. The inventors of that time were contrary to those who achieve things in modern society exclusively male.
But the bubbles make the diver fall deeper, duzn‘t it?
Btw, there was a video floating around some time ago (2016 olympiade?) of a olympic jump from way back in time (1960 or so), which was just a totally perfect, simple jump. 2^24 more elegant than nowadays‘ flipflopping down…
The UNTERSCHIED. Gotta meditate [emoji3284].
I've looked it up! 😀But the bubbles make the diver fall deeper, duzn‘t it?
The safety precautions include minimum and maximum pool depths for optimum water pressure.
The diving well for Olympic diving must be a minimum of 5m deep. This allows it to be used for the 10m platform diving competition and the 3m springboard competition.
Actually Tom, 1Hz is one hertz.
The rule is that, when written out in full, a unit corresponding to a person's name is not capitalised.
Fine. But it's certainly not one hert.
Tom
The rule is that, when written out in full, a unit corresponding to a person's name is not capitalized.
Really? I didn't know that. Are you sure about that?
Jan
It is right. Both are done but the official rule is as Galu describes. In my school we learnt writing with capital. Same with writing 1.5V or 1.5 V…. Both being better than 1.5v or 1.5 v
I'm sure, Jan.Really? I didn't know that. Are you sure about that?
As with every SI unit named for a person, its symbol starts with an upper case letter (Hz), but when written in full it follows the rules for capitalisation of a common noun; i.e., "hertz" becomes capitalised at the beginning of a sentence and in titles, but is otherwise in lower case.
Fair enough.
The rule book only stipulates for competitions so they could be used differently during training.
Bubble machines are allowed during competition but 'the machine should only be used for this purpose if it creates sufficient water agitation when working with very low pressure; otherwise a horizontal water sprinkler system shall be used.'
I'm sure, Jan.
So in languages like German in which common nouns are always capitalized the Hertz too should be capitalized, yes?
Blow low pressure bubbles or capitalize Hertz?
Being German it feels wrong not to capitalize it.
Jan, I too am surprised. Even if correct, I think respect is due so I may just have to keep breaking the 'rule'.Really? I didn't know that. Are you sure about that?
Okay, so after an incredibly involved 3 minute discovery session, I will bow to those who knew more. Even when the subject contains a proper noun, in this case a persons name, it is irrelevant and the result is a common noun.
Thank you fellas, that research was exhausting. Like Jan and others, I found it really hert.
- General Interest
- Everything Else
- Those pesky Abbreviations!
