500W (4ohm) GaN Class D Modules - Starkrimson Ultra
Doing some listening with Paradigm Monitor 9 speakers.
I'm mostly done with the surface mount parts on my boards. I treated myself to an HDMI microscope to aid in this and future builds. It has made populating the boards an enjoyable task. I have a few parts on backorder until late August. My plan is to finish the surface mount parts, then do the case work while I wait.
I hope to have the build complete some time in September.
Have you posted any phase plots?
I’m just curious as I have been reading about Technics GaN implementation about higher switching speeds.
Not that I’m unhappy, your amps are spectacular, I got my mono block for my center channel built yesterday. Put it in a slim Ghent case, just missing your beautiful logo : (
GaN Amplifier Module - Orchard Audio
Scroll down to test results section. Phase plots are posted.
Here is an Fyi for builders who want to utilize both balanced and unbalanced inputs. I had a small troubleshooting session after realizing my amp was a bit noisy at idle when using XLR inputs, with RCA shorting plugs in place. I removed the RCA wiring and jumped the unbalanced input at the terminal block. The noise went away. Then, I changed the RCA wire to a shielded one. This resolved my issue.
Can you share your complete alternative parts list that Leo gave you? I'm considering just wall mounting the boards. I'd be fine with just a metal sheet with the stand-off holes pre-drilled and all the connectors necessary.
I am under an NDA for the parts list and want to be respectful of that. If Leo confirms that you are also under the NDA, I will help out however I can via PM.
Leo also mentioned that he's updated the BOM since my build. Possibly the new version has more parts availability.
Take care!
I have the boards from you already. I was just looking for an inexpensive way to get it connected. I'm not even sure I will do an enclosure, but I certainly need all the connectors, and I would love it if I could get a sheet with pre-drilled holes for the standoffs.
I provided a drawing that shows all hole locations. Did you not get it? Email me, I'll send it to you.
