AB100 Class AB Power Amplifier
Here are some info files. for the sch and stuffing guide posted. hope its the same thing you want.
  • hole drilling marking location.pdf
  • AB-100 TO-247-R1-4CAPS-BOM.zip
  • ab-100 to-247-r1-4caps-top-DXF FILE.zip
hello jk556,
here are the updated gerbers as per the above quoted post.
no major changes except option for 2 big 35 mm caps instead of 4 smaller caps and doubling up of traces at some places.
Hi Prasi,
Really awesome thank you so much, you are really helpful.
Just a quick question in the new schematic it just looks like you might be missing a via where the J3 connects to ground on the right hand side. See attached.
Im assuming the colors indicate top or bottom copper.
A little progress.
First time building an amp chassis.
Makes any more easier though.
A couple of questions for those who have ventured down this path before.
On the PSU why is this amp not required to have CRC filtering?
I mean I have seen a couple of builds that have a cap bank prior to the amp boards with all of the caps just jumpered together.
Sorry if it is a naïve question, just wondering.
Also, would a 38 volt tranny be to much with the standard BOM?
A little progress.
As far as I know with my limited knowledge, it is because while a Class A amplifier has a constant current consumption, Class AB amplifiers current consumption depends on dynamic spikes in music, so it isn't so constant. Moreover, serial resistances between PS capacitors will increase internal resistance of PS, which isn't good. It would decrease the damping factor of the amplifier.
I don't know if I was understandable.
I hope at least I'm right.
I like your sturdy chassis!
Douglas Self warns against doing this in a sloppy & haphazard way. He even gives it a name: "Distortion Five: Rail Decoupling Distortion". It's in his power amplifier book (all editions).
Google gives you a general idea of what he has to say, link
Thank you Mark .
Doug Self :
"5. Non-linearity caused by large rail-decoupling capacitors feeding the distorted signals on the supply lines into the signal ground . This seems to be the reason many amplifiers have rising THD at low frequencies. Examining one commercial amplifier kit, I found that rerouting the decoupler ground-return reduced THD at 20 Hz by a factor of three."
I am interested in learning what the right and wrong way of routing the decoupler ground-return is .
I'll be using the Prasi board with 2 caps . My thoughts were that to add another 2 or 4 caps off-board , after the rectifier would not be a problem . Perhaps 2x 6800uF on the boards , and 2x CR of 6800uF and 1e in series off-board .
Prasi also provides the option of a 10e ground-lift at the input on his layout , which I guess may also help with this problem .
Attached Prasi layout schematic as reference .
One "trick" you can do to ensure better than average rail decoupler layout, is to put a phony baloney 1 ohm resistor in your schematic and in your PCB layout. This resistor guarantees that the rail decouplers are connected to each other "upstream" of their common connection to power supply ground.
Then when you stuff the board, you can install whatever resistance you wish into that footprint. 1 ohms? sure! 0.1 ohms? sure! Jumper wire (0.0 ohms)? sure! You'll still have a better than average layout topology.
_
