Daniel Hertz Levinson M1 wow
Obviously only one can solve the mystery (For once I allow myself shameless bragging) :joker::yawn::yikes::yuck::wiz::eek::scratch2: :cool:
Here's a clue.
Around the time the M1 was launched, about 10 years ago, I was researching horn-throat transitions.
If you take a closer look at the Hertz horns...
You'll notice the throat section differs from similar horns, like this Monacor MRH-300 aka P.Audio PH-94:
The origin/inspiration.
  • ET_Horn_and_Driver_Technology.pdf
  • US8477979_One Systems Equivalent Throat Technology.pdf
Interesting research, is that a 1" or 1.4" Horn flare?
A couple of close up images of the M1 horn
The M1 Horn flare
Close-up of the M1 horn flare
DM :)
AX tech editor
Joined 2002
Looking at the photo's - it looks like a common *commercial (cast aluminum) horn that has been cut-out at the entrance and has a custom guide-adapter plate to increase expansion from the compression driver into the horn. (..and obviously the external mount plate (chrome-plate) is custom as well).
*and the horn is being used horizontally with its vertical orientation (resulting in narrower horizontal dispersion with a higher spl-loss rate off-axis.)
I built a 3-way (partly) modelled on the M1, using Faital Pro 18 inch sealed 'sub' (powered by 500-watt MiniDSP amps), Beyma 12 inch mid and Beyma TPL150 in custom CNC'd waveguide. Passive LR2 xover for the mid/horn (200Hz / 2,500Hz). Very big/clean output. Paired with Weston Acoustic Class A power amps and pre-amp. For a gent in Malaysia. Personally, I like my 3-way horn rig (CNC'd) myself, with Altec 15 416 bass in my owned designed horn (ported), Yuichi 290 plus 3,000Hz lathe turned tractrix horn. All passive xover, 500Hz/3,000Hz LR2.
Reactions: 4 users
@atilsley Thanks most interesting
My own design will take some cues from the M1 but will use separate modules for each driver the cabinets will be over engineered as I did with my hommage to the Wilson X1 some 25 years ago!! my first real big build in my 20s
My use of separate modules means I can play about with diffeent drivers with dedicated crossovers.
Early days with the concept though.
Great!
I plan to design a speaker with similar approach with Beyma TPL200 + 10MCF400Nd and probably 21PW1400Fe V2.
Can you name your 12" mid please?
J.
