LuFo Amp - 39w SE Class A from 28v Rail
I now have 400 pcs of LD1014D. There are several different arrangements of numerical strings in adjacent location on the tape that holds the parts. I will do some sorting and curve tracing and see if I can discover a pattern.
As long as all the parts have the triode curves, I don't care that the parts are not all identically marked.
Having tested and sorted ~500 pcs from Mr Pass's stash, as long as you have a large enough population, you will get mostly (>95%) matched pairs.
I got a strip of 50 last week, a mix of 3 different type. A few of those I can't see the marking without a magnifier.
My guess is that the original manufacturer made this strip and placed these parts. I doubt that a recycler in China goes to the trouble of mounting these in a strip that is used in a pick-and-place machine and then sells them for USD $0.17/each.
Founder of XSA-Labs
Joined 2012
960783d1624028577-lufo-amp-39w-se-class-28v-rail-9332e4b4-83d2-4c8c-9ebc-f2e19cbf6e1e-jpg
That looks like an completely incorrect part error on the factory that loaded the tape reel. That part has a different tab shape and the simple is in a different location altogether. Is it even labeled LD1014D?
Yes, it is labeled LD1014D. The date/lot code is different than the others - it ends in H, whereas the other package type has a code ending in G. Perhaps it's just from another production run?
It is all speculation until you measure it.
Unfortunately, it will likely be a long while before I can confirm either way.
Joined 2014
LuFo Progress update
LuFo amp heatsinks are drilled and tapped, Mosfets and LU1014 soldered in.
Next step.... PowerUp!! Hopefully, I’ll be able to get time this week to do that.
