QUAD 63 (and later) Delay Line Inductors
AX tech editor
Joined 2002
I also think it does mean that making the DD amp frequency response the inverse of what I measure with the input transformer, is not necessarily correct.
It does not take into account that the source impedance of the xformer and the DD are different.
But I will follow Hans' suggestion to measure the acoustic response in both cases. UMIK-2 is on its way ;-)
Jan
AX tech editor
Joined 2002
Got some time today and setup the miniDSP with the equalizer and the roll-off above 12kHz to mimic the response at the panels in the original situation.
The speaker now sounds less thin and more balanced. Funny how much difference a few dB in the midrange can make. Donald Fagen's The New Frontier sounds really nice.
But I realized I have made an error in the sims and the measurement to determine the required drive current. I have fed one side of the panel with the output of the single channel prototype, grounding the other terminal of the panel.
That works fine, but of course the current requirement is only half of what it should be when the other panel terminal is driven in opposite phase.
Driving that opposite side of the panel model with an inverse version of the main output (simulator) shows double the current, as expected.
You live and learn, I guess.
Jan
AX tech editor
Joined 2002
John Atkinson had already done it for me ;-)
Jan
mkc
Joined 2002
Hi Jan,
I have linked to a scan I made of a test with meaurements in a local hifi magazine earlier in this thread. I also discovered I have the original test from Hifi-News 1981. It actually also have some nice measurements. I can make a scan if anyone is interested?
P.S. Given the voltages involved I actually considered if we need to have a daily "heartbeat" post from you :D
Mogens
Joined 2004
For years I have used a 6 dB roll off for 63s. Always with a sub. If you look at the typical power distribution for music.( except hip hop) it's centered around 100 Hz. Removing the bass demands can significantly increase the max output. Also the panels have a resonance around 80 Hz as I remember that would be good to avoid.
AX tech editor
Joined 2002
Doing so at LF may usefully increase power handling/avoidance of a strike though, overall?
Settling for 40hz, say, vs a DD amp's ability to pin the thing at ELF, simply from a recording transient or similar.
(from an amateur just watching this with interest ...)
That was my thinking.
@Hans: is that natural rolloff caused by the xformers and xover parts? I will not go through that of course.
Jan
