well, I believe there is not much importance what's Idss of JFet down (CCS), as long you're able to set it to desired current
I think I got it now. We want to control the current through Q1. That means Q2 including the resistor brake is lower than Q1ˋs max current. Right?
Alright, just updating in case someone else has the same issue as me at some point.
I connected a wire from the volume pot to one of the grounds on the PCB and it fixed the hum.
Guessing the anodizing was insulating the put from the chassis
Can I use the B1K as a simple buffer with no volume control between my source and amplifier? The source I am using has remote volume control and I want the tube and H2 sound without futzing over a volume control.
Thanks for any replies.
I don't see why not, if your amp can handle 16dB of gain between it and the source. At least for DACs, the volume control is digital so you might be losing some dynamic range if you choose to control the volume that way.
It works well without pot between a Minidsp SHD Studio I use for volume control and power amp. The SHD has 2dB gain.Can I use the B1K as a simple buffer with no volume control between my source and amplifier? The source I am using has remote volume control and I want the tube and H2 sound without futzing over a volume control.
On second thought to be sure not accidentally get to high volume I put a 35kOhm resistor between + and - of both NuTube inputs and an extra 15kOhm resistor on both + inputs to simulate a 2/3 setting of a volume knob.
I have a hybrid power amp in which the B1K behaves as a buffer with no volume control. Others, perhaps Nelson himself even, recommended that I should implement a voltage divider on my inputs. I seem to recall the notion about it acting as some kind of regulator that the volume pot naturally imparted. You might want to search posts in this thread to read what more knowledgeable people said.
Of course the volume pot is what provides the input impedence as the B1K is normally built. I'm not sure what the input impedence would be without one. So you if don't want any attenuation, you should probably just put a fixed 50K resistor between the input and the ground. Or else, as @jaaptina suggests, some other combination that will add up to 50K, though I would think a 100K pot would work just fine, too. I'm using an ALPS 100K pot with mine now...
I assume you mean what the input impedence woudl be without the pot? If so, for my own education, where does that number come from? The resistors that follow the input cap?
It might sound strange, but you can consider the two 221k resistors in parallel so you end up at 110k.
There are some text around on the web, e.g. FET and BJT Difference | Impedance at the FET Gate | Voltage gain
Hum question
I built the kit perfectly stock. I have a little bit of ringing, but only when the box is touched. But there is a hum. It’s not 60hz or 120hz. Someone in an earlier post said they heard a sound like an active cell phone near a radio. Not exactly crackling, but not periodic. The “hum” doesn’t go away when I change from input 1 to 2. And it doesn’t seem to be affected by the volume control. Any ideas where to start?
For the hum, check your ground wires again. Make sure there are no loops or interruption of the ground continuity from input to output. The case should be grounded to the printed circuit board.
Yves
Yves
Are you sure the board should be grounded to the case? I don’t see any place that would happen (deliberately). I did try using a jumper to attach ground on the board to a screw that taps into the chassis, but it made no difference.
My NuTube and amp hums and hisses loudly when the amp is connected to net ground. I removed the net ground connection. Now its completely silent.Are you sure the board should be grounded to the case? I don’t see any place that would happen (deliberately). I did try using a jumper to attach ground on the board to a screw that taps into the chassis, but it made no difference.
In another room it doesn't hum and hiss while connected to net ground. So in my case it seems related to the shared outlet (with TV, modem etc). I did look for the ground loop in my 3 box stereo setup (streamer, dac and NuTube/amp), but could not find it. That is why I keep using it without net ground connection.
Sorry to be such a noob, but what is “net ground”? I looked it up, didn’t get definitive answer. I assume it’s what I call “earth ground” or the “green wire” in the US?
I tried an IEC wire with the 3rd prong removed. Is that what you are suggesting? Sadly, that didn’t help.
Yes that solved my problem. Can't give you other suggestions.Sorry to be such a noob, but what is “net ground”? I looked it up, didn’t get definitive answer. I assume it’s what I call “earth ground” or the “green wire” in the US?
Thanks, Jaaptina,
Can anybody tell me whether the board is supposed to be grounded to the chassis? The only way I see that happening is through the screws that hold the board down. The screws seem to be attached to a ground trace on the board, but then they attach to the chassis via threads through anodized holes. I don’t get any continuity from board ground to chassis other than by touching those screws. is that a problem? Should I have sanded the chassis before attaching the board?
- B1 with Korg Triode
