Ultimate 4U 500mm Chassis - Who is interested?
Base Plate Option
  • Standard Aluminium 3mm or 4mm
    Votes: 5 23.8%
  • Aluminium + Custom Perforated Steel Base Plate 470mm to 480mm
    Votes: 16 76.2%
  • Total voters
    21
  • Poll closed .
:clown:
This chassis is massive overkill for an M2x. An M2x can easily fit in a 2.5U by 400mm deep, with a full dual-mono PSU. But don't let that stop you. 😉
Not quite sure what a 2.5U is since one isn't listed in the store.
I guess I have been assuming that this 400mm 4U would have the same UMS drilled heatsinks and back plate as the standard Deluxe 4U and at a price in between the Deluxe 4U and Deluxe 5U. If I am reading the pricing in the store correctly, adding those features to a 3U or 2U quickly boosts the price about the Deluxe versions.
But you are right, the M2x doesn't need the height of a 4U but a dual mono build does need that 400mm depth, or at least my fat hands need that much space to connect the wires.
