If not, easily executed. Just checked.
As one of the drivers used in FHXL it will become available for free use. Have to separate it out of the planset.
dave
dave
Shouldn’t be all that much different from the design for A10.3 that I’ve running quite happily for several years now?
...so an 8" MarkAudio wideband driver.IIRC there was some interest in designing one, or at least a unit with a ~10in basket diameter. However, as far as I know there isn't such a driver imminent. I'll see if I can find out though.
I would hope it has a higher sensitivity than the current highest in the line up A12p.
As noted, there is no such drive unit currently in existance, so hopes, fears and pronouncements over size are a trifle premature at this time. 😉
dave
Hi Dave,
In order to get the plans for FHXL for A11MS I need to make a donation to Diyaudio?
Dejan
That is an interesting question. It is assummed that it will be used by someone who has already built FHXL, but technically iy is not needed, morally is a different query.
dave
dave
I'm interested in FHXL too. Although, I have not decided yet between FHXL and Pensil A11.
I would love to have the plans for FHXL and for the center channel speaker and I will make a donation if that is what is required to get them 🙂
Will the MAOP 11 have better frequency response than the MAOP 10?
Will the MAOP 11 still fit into the FHXL designed for the MAOP 10 / Alpair 10?
Respectively,
-How do you define 'better'?
-Yes, but it will have an alignment roughly equivalent to the Pluvia 11 that it is based on, not the Alpair 10, which is a different drive unit.
With the MAOP 11 having a 1cm larger diameter, will the MAOP 11 have deeper bass than the MAOP 10?
Will the mids and highs be the same?
note: the above comparison assumes being used in the same FHXL
Respectively,
The bass extension is not directly associated with driver size.
In terms of bass extension potential, A12pw, A10.2, EL70/Pluvia 7, and then the rest. Pluvia 11, MAOP 11, A11ms do not have a particularily low potential. A10s will go lower.
But in an enclosure like teh FHXL, where the box is a main contributor to bass extention, the extention is about the same. Mostly.
dave
dave
There is little difference in sound quality(low, mid, high) between MAOP10 and MAOP11 on same box.
Please choose by looks and price.
MAOP10 - YouTube
Close to you~遥かなる影 / 深町純 - YouTube
MAOP11 - YouTube
夜明け - MAOP11 - YouTube
MAOP10 - YouTube
MAOP11 - YouTube
Good Morning Dave!
You mentioned that you might have a pair of P7HD's available. Are they still available? Cost and shipping to Ontario? Thanks!
P7HD ar estill in the queue to get installed in FH3 and listened to, and currently their location is unknown. The P7PHD just came out and they ar eup for grabs. The basement has been transformed in th elast 2 weeks and i am finding all sorts of things.
A7.3 i do have (have to measure the silver ones, half are spoken for).
dave
dave
Thanks Dave! I will wait for your message. If you cannot find them and I should go elsewhere, let me know. Thanks
- Full Range
- New Markaudio Drivers
