Shunt Cascode Driver meets UNSET for Push-Pull
If the Shunt Cascode's current source is replaced by resistors, the power supply rejection is poor like this. To get the performance back to the level with a current source, a regulated supply must be used. Much more complicated than a current source.
That was one of the thing I would have simulated tonight. Thanks for your suggestion!
I'm very proud to have both you Rod and George writing on this thread.
One thing I don't like...
If the Shunt Cascode's current source is replaced by resistors [R12, R20 in this case] the performance is degraded. It's because the power supply rejection is poor like this. To get the performance back to the level with a current source, a regulated supply must be used. Much more complicated than a current source.
Agree entirely for an SE amp. But I had a regulated supply available anyway. If the cascode reference voltage is derived with a divider from the same B+ that is supplying the anode resistors, and you bypass the divider output with a capacitor to B+ rather than ground, the PSRR is quite good. Any residual noise from the power suppy that finds it way to the output of the shunt cascode is common mode so is rejected in a push-pull output stage. Just trying to keep things simple.
I attach here the updated schematic with resistor loaded LTPI (but still CCS on the cathode). Performance is a little bit worst with such a low load, but almost unchanged with 10k and 200V lost on those resistors.
1k is definitely too low, I used 2.7k from a regulated rail that was about 18V higher than the anode voltage. Obviously higher is better. CCS is ideal but you need 4 of them for stereo and have to adjust all of them. If you have a nice pcb with all that on there that's great but I was doing it on the cheap with veroboard and P2P.
If the cascode reference voltage is derived with a divider from the same B+ that is supplying the anode resistors, and you bypass the divider output with a capacitor to B+ rather than ground, the PSRR is quite good. Just trying to keep things simple.
Thanks, that reminds me of my readings on tubecad.com and I will try to inject noise to see how it will react.
I will check a reasonable voltage for the PI, also considering I would like to simplify the power supply as well. Having around +140V bias voltage for the PMOSFET, and -200V as reference voltage for the 27 kOhm load resistors, a +-200V could be a good starting point.
So the voltage divider could be 560k on 470k (that gives 91V) with 100n in parallel with 560k.
5.6 kOhm load for the PI will guarantee (200-91)/5.6k = 19.5 mA
It will dissipate 2.2 W, so a 5W resistor is needed.
Then I need to set the PI's tail CCS to center the working point of the stage between -200 V and +90V, so around -55V, that means 2mA on 27 kOhm with no signal, so the CCS must be set at 19.5 x 2 - 2 x 2 = 35 mA.
The 27k load resistor will dissipate 100 mW, so a 1W resistor is enough.
Thanks, I will try different options, +-200Vdc supply could be an easy solution together with +500V for the plates, to simplify the PSU.
I need to do something similar, I have no competences to design a pcb for an amp that has such gain and no phase inversion, without having oscillations.
This is the schematic I will simulate injecting noise on different parts of the PSU.
attachment.php
PT could have only three secondaries:
0-360V plus 0-150V plus 3.15-0-3.15V
...but I have to say that I don't like to dissipate that much on R22, most probably another supply just for the CCS would be better also on the thermal point of view.
Performance is unaltered, same as before up to 80 Wrms.
I had a few thoughts:
1. I made the curves posted above by following the procedure in O.H. Schade's paper. They are calculated, not measured.
2. I think that you will get better results if you don't do the UL for the screens. Remember that UL is just a compromise between triode connection and pentode connection. To get behavior like the magenta curves above, you need full pentode connection. UL will give you curve shapes that are somewhere between the light blue curves and the magenta curves, which I would expect to make them worse.
UL never made sense to me as an optimal solution. You take a nonlinearity that originated in the g1-plate characteristic and you apply a correction to g2, which has completely different characteristics, so the distortion correction isn't as good as it would be as if you applied that same amount of feedback to g1.
3. A while back I drew up a plan for a push-pull experiment combining the Corona input stage with something similar to the UNSET output stage. I haven't built this yet, but I've attached it here in case there is anything of interest to you in it.
I like the idea of a cascode providing high gain in an input stage rather than a pentode. Maybe it offers some noise performance benefits?
