Beefed up Amp Camp Amp?
Tony, did you end up building the 48v version of the ACA?
yes i did...it was awesome to say the least....i am hooked...
i used 4 off 48vdc/4A power bricks, one each channel...
IRFP150 as recommended by Zen Mod..
chassis from AliExpress...
boards from JLPCB....
i am now on my second build, this time a 6 channel for a two way bi-amp...
Nice one Tony!
Using 48V, what's the power wattage output you get ?
If you're using passive cooling, don't your heatsinks get too hot in the Philippines?
I've built the standard 19V version. It's nice, but it's not powerful enough. I might try to run it at 24V, but I'm curious about 48V.
2A3CA A25 OTL
25W 2A3 Kalimbang with no global negative feedback. 😀
Code:
N-Period=all
Fourier components of V(out)
DC component:-0.000720217
Harmonic	Frequency	 Fourier 	Normalized	 Phase  	Normalized
 Number 	  [Hz]   	Component	 Component	[degree]	Phase [deg]
    1   	1.000e+03	4.000e+00	1.000e+00	 -179.66°	    0.00°
    2   	2.000e+03	1.216e-02	3.039e-03	   89.97°	  269.63°
    3   	3.000e+03	4.406e-04	1.101e-04	 -173.58°	    6.08°
    4   	4.000e+03	1.899e-05	4.748e-06	  -79.74°	   99.92°
    5   	5.000e+03	4.696e-06	1.174e-06	    6.21°	  185.87°
    6   	6.000e+03	2.935e-06	7.339e-07	    1.37°	  181.03°
    7   	7.000e+03	2.498e-06	6.246e-07	    0.12°	  179.78°
    8   	8.000e+03	2.194e-06	5.484e-07	    0.16°	  179.82°
    9   	9.000e+03	1.961e-06	4.902e-07	    0.20°	  179.86°
Total Harmonic Distortion: 0.304146%(0.304667%)
Just trying to tease our audiophile friend Tony. You know the drill, cheapskates like me will sim 2a3 but use nice (but nobody wants) sweep tubes like the pl36, e235l, 6bq6gt, 6av5gt, 6p31s and the likes. 😉
