"WHAMMY" Pass DIY headphone amp guide
Let them run continuously for at least a week - the 'sound' improves dramatically.
If you haven't added the small caps directly to the chip's socket pins, suggest you do this.
For rails of +/-18V, you can add a simple transistor cap multiplier type circuit and drop a couple of volts or add a low dropout regulator in place of the series resistors to pull rails down to about +/- 15v.
This? (See pic) Love it since it's attached to the extra adapter (was in the V6 case) and therefore reversible for other rolling.
@advdesignguru has a couple of posts about this from back in Sept. (#2911). I happened to have the .33u on hand... 15.1VDC now... case is 12 degrees cooler... thanks for the awareness check @RafaPolit!
No comment on audio—first blush, no real change—but need to listen more of course.
Update: Temp on case of V5i came up to where it was before at the slightly higher, but debatably over juiced voltage... guess around 100F is normal?
600 ohm headphones
Built the Whammy with the understanding that it would handle most headphones. I have some 600 ohm AKG Sextetts that sound pretty flat with the Whammy. All of my vintage receivers/integrated amps kind of destroy the Whammy for sound. Not sure if there is anything that I can do to modify it to improve this. On the other hand, since I have all of this other equipment, probably not necessary.
