25W Single Ended Hammond 193V Choke Loaded 2SK180 L'Amp
Not sure if Lundahl has a choke with a sufficient current rating. Their amorhous chokes are on pitifully small cores, so this is probably not a good option. It is my belief that all things being equal an amorphous core needs to be substantially larger.
I made five of these a few years ago for the PS of my Aleph 5.
3.2mh 0.65 Ohm
I would buy off the shelf items today though as it was a bit of a chore to do. The ones I pointed to earlier are about £15 each.
I was going to ask Ben & generg the same question regarding a constant current load
I have listened to my BAF2015 THF-51S (CCS/Mu follower/common source) and the choke loaded common source 2SK180/THF-51S and I did not notice any of what I would consider significant difference in sound. But that is me, and someone else may notice differences.
One practical disadvantage of the CCS/Mu follower is the much higher V+ required. That means higher voltage power supply with higher voltage capacitors and transformer, and higher power dissipation necessitating much more heat sinking.
On another note, I was thinking of a name for the follower version since it is a keeper for me. Along the lines of the Michael Rothacher's MoFo, it could be a ToFo. But then it could be "A Fokin Amp".😀
To end this on a sunny but cool morning, here is my favorite Mr. Rogers interview:
Mr Rogers interviews a bass player - YouTube
Around 50mH seems to be the minimum for a full range amp. 100mH is better.
Hammond has some offerings that might work:
Part No. Inductance mH D.C. Current Resistance Weight
(Millihenries) (Amps) (Ohms) (lbs.)
195R10 50 10 0.165 26 ~$177
195S4 70 4 0.6 - ~$68 each
195T10 100 10 0.42 35 ~$300 each
Looks like a comparison of the 193V and the 195S4 could be interesting.
Ben, if you think it might be worthwhile and you're up for testing, measuring, and your wonderful reporting, I'll split the cost of a 195S4 (including shipping) with you.
The Hammonds are wound without any regard towards minimising parasitic capacitance and on the cheapest cores money can buy. I have a fair idea of the the quality of their tube transformers and chokes and would be very surprised if the high current parts are much better.
The Lundahl PS chokes otoh are made using the same winding geometry as their plate chokes.
I, too, like the sound of the my 2SJ28 source follower amp compared its previous iteration in common source mode. It is CCS loaded, not choke though, but it is driven by a Hammond choke loaded 2SK82 voltage amp.
Like Ben said, the sound to me is cleaner, yet still sweet. I also use a Luminaria preamp, so it has enough 2nd order harmonics and the source follower amp's low harmonics adds a little bit, but not too much as compared to the common source amp.
I think that the low impedance of the SITs allow the use of lower inductance chokes and their capacitances do not affect the signal as much.
I just started building a Hammond choke loaded 2SK180 follower amp and that will provide more data.
Hi GnuB,
I am not up to taking my amp apart to try a different choke. Sorry.
Looking at the numbers, the 193V is 150mH, 3A, 1.0 Ohm DCR for $89 whereas the 195S4 is 70mH, 4A, 0.6 Ohm DCR for $68.
The higher inductance of the 193V will result in better low frequency response and lower distortion. Perhaps in real life it may not be noticeable. But in diy, I would go with the 193V for the extra $21 each.
