25W Single Ended Hammond 193V Choke Loaded 2SK180 L'Amp
Joined 2012
Some Bad News, and Some Good News To Follow
I did not experience instability when I tested the amplifier section with my lab power supply, and no instability when I first had the amplifiers running with their own power supplies. That was in December when the weather was cold and the ambient temperature was lower.
However lately the amplifiers have not been stable. The current has been wandering upwards, especially when the line AC drifts up to 121V or so from a low of 117 to 118V. It would wander up and up with no sign of stopping.
I tried adding source resistors, starting at 0.1R and increasing in 0.1R increments until the right channel stabilized with 0.4R and the left channel at 0.6R. Interestingly, the right channel's Vgs before the addition of source resistors was lower then the left channel's Vgs.
The plus with the addition of the source resistors was lower harmonic distortion but a negative was the lowering of the power output. I measured the maximum output of the left channel at 15W.
Since testing with the regulated lab supply gave stable results, I put together a simple regulation stage with a low dropout LT1084 regulator and installed it between the power supply and the 193V, and removed the source resistors. Unfortunately, that did not stabilize the current. Yet during testing with the regulated lab supply, the amplifier stage was stable. The lab supply has a current regulator but I did not recall it being activated. So perhaps the 2SK180 changed a bit after burn-in?
So in frustration, I pulled the 2SK180 and put in a recently purchased THF-51S. No problem with the THF-51S at all. The current was stable, with only small fluctuations that followed th AC line voltage.
So at this point I would say that the THF-51S is preferred SIT to use in this implementation. So it should be "25W Single Ended Hammond 193V Choke Loaded THF-51S L'Amp".
So that is the bad news for the 2SK180 (but good news for the THF-51S).
Now for the good news for the 2SK180. I still wanted to make use of the 2SK180 in some way. I decided to put the 2SK180 back into the amplifier but use it in a different implementation. I wired it up as a follower, putting the 193V after the 2SK180 and taking the speaker out from between the 1SK180 and 193V, and it was stable. Being a follower, it has no voltage gain so it needs a preamp with enough voltage output or a voltage gain stage in front of the 2SLK180 output stage. The harmonic distortion is also significantly lower as a follower.
In my system my Luminaria preamp has about 17dB of gain (50X). It is nearly but not quite enough since my digital source, a TDA1541A dac with only a 60R I/V resistor and no voltage gain stage, has an output voltage of about 0.1V. So I inserted my ACP+ headphone amp/preamp in between the DAC and Luminaria and that provided enough voltage.
I have some Russian 2KP296 on the way from Eastern Europe and I will do a voltage gain stage for the amp. It will be SIT voltage gain with SIT current gain.
I have listened to this for several hours now and I really like the sound. The 2SK180 follower amp seems to have a clarity that the 2SK180/THF-51S 193V L'Amp and my BAF2015 THF-51S amp do not have. It is a subtle but noticeable difference. Due to the follower's lower harmonic distortion? More listening to do and distortion measurements to come.
So my experience:
-2SK180 needs source resistor if implemented as common source amplifier (voltage and current gain).
-THF-51S (drop-in replacement for 2SK180) is stable as common source amplifier.
-2SK180 and Hammond 193V as common drain amplifier (follower with only current gain) is stable and seems to have an edge in sound. Appropriate source/preamp with high voltage output required.
So far I really like the sound of the 2SK180 as a follower.
Joined 2009
Interesting results! I may add that my SK82 build with the Hammond had no bias stability problems ten years ago.
And yes I had the THF51 as well in common drain and common source configuration with a chain of 9 x 5 Ohm resistors and high voltage around 90V and the sound of the common drain version had this touch of more clarity you described. (three years ago)
I find it interesting that the THS51 does not go into thermal runaway. It is, after all, the obvious thing to do. Perhaps the cooling is very efficient and keeps the temperature low.
Interesting too, but not unexpected, that the follower sounds better. Minimalism looks cool but seldom sounds good.
