I just loaded the Gerber files in the KiCad gerber viewer and it does appear that the board is smaller than what JLCPCB is detecting. The output transistors along with two drill holes appear as part of the PCB area and then the PCB outline.
Any chance that the originator can upload a fixed version with the correct PCB outline in the edge cuts?
Edit: I have attached an image of the errors in the outline layer where you can see the outline extending beyond the PCB dimensions.
Hi Kozard,
here is modded gerber zip file that doesnt have drill for output which might be causing wrong outline with jlcpcb.
hopefully it will work now.
regards
prasi
Would it be a good idea to run this circuit with to92 mosfets for powering opamps close to their pins, post regulator l, lets say 317/337, where the layout forces the traces to be longer than optimal? With the opamps small current dra the cmx's heat will be also low.
I am planning to use CAP-MX for my upcoming F6 build. Is 20V (AS4220) or 22V (AS4222) transformer better for the 24V F6 after the CAP-MX voltage drop? Just want to confirm before I make the transformer purchase. Thank you,
The gerbers from back in post #280 don't seem to work with JLPCB. Same issue with the earlier revision of that board. Any advice please?
Prasi, your mastery of PCB layout has inspired v2 of my design. I have attempted to move "all the action" to the output ground connection.
The grounds of C3, C4, R3, R4 have been moved to their own ground plane. The grounds of C1, C2, R1 are run to the output in their own planes (top and bottom). The two only connect at the output faston and surrounding vias.
What do you think?
hi, are there any published gerber files of your multiplier? thanks and good job!
I couldn't get the diode version or later dc input with led version to work on JLPCB. But the one above works
It was 2 +signs in the filename tha made it not work.I removed rgem an it worked.
But are there a schema and a BOM for it?
I renamed and then it woukd load into JLPCB but it still wasn't working properly. Even the previous revision with no 'special characters' wouldn't work
Thank you Mark for your suggestions.
As per the Juma's schematic , the values are 12k Ohm for the R2 and R6.
Also requires a regulated input for the circuit , so the on-board rectifiers + CRC may not be such a good idea.
Prasi
Hi Prasi, I wanted to ask you if there are gerber files or a specific 3d about these 2 of your pcbs. Thank's for your job. Good day!
My thoughts exactly!We are too lucky that we have you here Prasi!
You are a very generous gentleman.
Best Regards.
Thimios.
What I wanted to add to this is that I really appreciate collaboration of xrk971, Mark Johnson, Gtose, Juma and others who contributed to this refined and revealing conversation.
I am using Capacitance Multiplier board created here and is available for purchase at pcbway.com. I intend to use Capacitance Multiplier with every amplifier I will ever build. Somewhere I have read that amplifier just modulates power provided from the power supply. I tend to agree with that even though that isn't entirely true. The truth is that a good power supply may make a great amplifier even much greater. And vice-versa: inadequate power supply may totally degrade the sound of otherwise good amplifier.
Thanks guys!🙂
I can´t find the schema or a BOM for Juma's Easy-Peasy Capacitance Multiplier
prasi or anyoe else have it?
https://ibb.co/x202JYQ
https://ibb.co/LZvdcXz
Hi Taso,
Here is gerbers file for second design. I cant find the other design.
also sch and layout.
I dont think anyone has tested this particular pcb design
regards
prasi
Hi, one question:
For this pcb/schematic, if i put all 4 mosfet identical, like irf840 or similar, can i have 4 multiplier for positive voltage?
I have to disconnect/separate the gnd connection?
https://ibb.co/yFQ6hhG
Thanks guys
It will not work as diode orientation is different. best not to try it.
rather you can cut pcb in half and use.
Hi Ryssen,
here is a parts list as exported from cad software. so it should help you in choosing appropriate parts.
regards
prasi
Hi Taso,
regards
prasi
Thanks Prasi, the R are 1/4w?
- Power Supplies
- Juma's Easy-Peasy Capacitance Multiplier
