Amplifier Modules and PCBs For Sale
  • Thread starter Thread starter Deleted member 148505
  • Start date Start date
On the other hand, Digi-key charges very high shipping costs of 21 euros in Germany if the order value is less than 50 euros. In contrast, Mouser always sends its parts free of shipping costs. For me, that's the reason to buy from Mouser. I'd rather wait two days longer.
Yeah, Mouser has had problems with both supply & fulfilling orders quickly recently. Digikey seems to be fine but are out of stock of opa1656 op amps as well (like Mouser).
Pete
My Mouser order (using UPS courier) has arrived last weekend. However my LCSC order with DHL courier was held by Philippine customs for a week now, looks like Covid surge problems.
2Vrms for SE/common mode signal, 4Vrms for differential full scale signal.
The module is shipped as default SE (unless requested)
PFFB has around 6dB negative feedback so it has a lower sensitivity.
4V? Website says 2v, unless that figure is for single-ended and single-ended is more sensitivity somehow?
Please confirm the 4Vrms for the SYLPH-D200 again, as the website says 2Vrms maximum.
Input sensitivity (PFFB disabled): 1V RMS
Input sensitivity (PFFB enabled): 2V RMS
Why are the values different for PFFB disabled and PFFB enabled?
Hmm no, with PFFB, the gain will be reduced so you need 2Vrms for SE and 4Vrms for balanced (2Vrms Hot to Gnd, 2Vrms cold to Gnd, 4Vrms full scale).
Without PFFB, you only need 1Vrms for SE and 2Vrms for Balanced connections.
You can reduce the gain by changing the resistors of the inverting opamps.
Thank you for the quick answer. So the variant "without PFFB" runs with 4Vrms.
For the variant "with PFFB", one volt less applies. In this case, does something have to be changed in the SYLPH-D200 at 4Vrms?
